 Brake master cylinder
simongd
Number of posts : 176
PostSubject: Brake master cylinder   Sat Dec 28, 2013 10:31 am
I need to get a good look at the brake master cylinder and vacuum as I have some brake fluid leaking out. It is only a tiny amount and the brake pedal makes a squelching sound when depressed. I hope it is just a seal which needs replacing but I cannot see it that area very well. Before I start taking covers off I just wanted to know if someone has experienced this issue.
Once I have taken off the covers I may just take it to the garage. It is in such an difficult location.
PostSubject: Re: Brake master cylinder   Sun Dec 29, 2013 11:32 am
Not done it but I think it is a dash out job, the master cylinder is infront of the servo which needs to be removed.
simongd
PostSubject: Re: Brake master cylinder   Fri Mar 06, 2015 9:27 pm
After being SORNd for a year, its time to fix this master cylinder. I have removed the dash and the master cylinder itself and see I need a seal repair kit. Anyone know where I could get one, or have the part numbers. Toyota want to sell me a complete cylinder. Maybe I can order just the gasket seal kit.
PostSubject: Re: Brake master cylinder   Sat Mar 07, 2015 6:28 pm
Any car factors should be able to sort you out on a seal kit, even Toyota should do an overhaul kit.
Logon to www.toyodiy.com and put your details in it should list the parts - this number may help at motor factors.
» THE MASTER OF SPIN ON IRAQ WAR
» Under the Category of "You Have Got To Be Fracking Kidding Me!!!!!"
» Won Park - The Master of Origami Paper Folding
» Lost Brilyn the Jazz Master in Slovenia!!!!!
» Setting up google web master tools
