 Engin Stalls
Gallie
Number of posts : 4
Home City : Walvisbay, Namibia
Model and year : Toyota HiAce Super Custom 3L
1995 MOdel
Registration date : 2013-12-30
PostSubject: Engin Stalls   Mon Dec 30, 2013 11:40 am
Hi, I have a Toyota HiAce 1995 Super Custom 3L Van, last week we went for a drive when the Auto transmission oil pipe burst, when we stoped the whole engin compartment was full of transmission oil, when we returned home, we cleaned the engin compartment with engin cleaner and the washed it off with water, repaired the pipe and refilled the transmission with oil, now when you start the engin the engin check light comes on and then the engin stalls, sometimes the engin will idle ok but as soon as you give the engin reffs its stalls.
What could be the problem? I've checked al the plugs, sensors everything.
Thanx
Gallie
PostSubject: Re: Engin Stalls   Mon Dec 30, 2013 5:08 pm
One of the many sensors may be bunged up with oil and/or cleaner. Give it another good clean and hose down and fingers crossed!
Gallie
Number of posts : 4
1995 MOdel
PostSubject: Re: Engin Stalls   Mon Dec 30, 2013 5:59 pm
We did the fault Code finding but there was nothing. When we started the van again we just heard n click sound and from then the van Idle and ref without Stalling. So What Ever the fault was Its fine now. Bit weird.
PostSubject: Re: Engin Stalls   Tue Dec 31, 2013 8:33 am
May have dried out?
Gallie
Number of posts : 4
1995 MOdel
PostSubject: Re: Engin Stalls   Wed Jan 01, 2014 7:59 am
We took the Van lastnight for test drive again, al was fine for about 10km than it began to stall again. As soon as you put your feet on the ref it makes a click sound infront of the dash and than it stalls.
labscty
Home City : high wycombe
Registration date : 2014-09-28
PostSubject: Re: Engin Stalls   Sun Sep 28, 2014 2:15 pm
got a 3litre turbo stat for a second then stops.if you turn key over engine goes but high revs.any one had same problem and how to sort it!!
Steward1957
Number of posts : 4
Home City : blantyre
Registration date : 2015-01-19
PostSubject: Re: Engin Stalls   Wed Jan 28, 2015 8:23 am
If you have a kz engine with the electronic fuel pump there are three screens on the pump that can cause you problems. On is located in the fuel return collector stem, one is located behind the fuel temp sensor and the other under the spill control valve. I had to clean all three after having problems with the engine stalling then let it sit for a few hours then it would start and run fine for a bit then stall again. After cleaning the first two screens because the third was very had to get at it ran better but still stalled out. I had to remove the fuel pump and even take off the injection head in order to remove the spill control valve but once I cleaned the screens it is running amazingly smooth. Once you take out the screens under the spill control valve you need to take the pack apart. there are 4 small screens together. There is a good video on you tube to show you how to do this.
PostSubject: Re: Engin Stalls   Wed Jan 28, 2015 9:34 pm
Thanks for that.
Screens = filters - for those of you who may be confused.
Engin Stalls
