 Bike rack for super custom hiace
agb75
Home City : vancouver
Registration date : 2014-05-19
PostSubject: Bike rack for super custom hiace   Mon May 19, 2014 8:12 pm
Hi All
I have a 1995 super custom hiace with a 2" lift, giving a little extra useful clearance for dirt roads, and am looking into fitting a bike rack to my van.  I see two options:
1/ 'Hang off the back van door type' rack.
2/ Fit a hitch and add a 'hitch mounted' bike rack
Has anyone done this?  I would appreciate any comments/learning points/tips...
This is my assessment so far:
My preference a Fiamma bike rack because it is
-door mounted so no loss of clearance due to hitch custom fit
-cost of fiamma rack less than hitch + hitch mounted rack
My questions
-fiamma door mounted racks are produced for VW vans - is a fiamma door mounted rack fully adjustable and easily fitted to a super custom back door?
-fiamma racks come in 2,3 and 4 bike capacity options.  Can a 2 bike option be purchased and an extension be put on to add +1 or +2 bikes?
-what is the best method of getting a fiamma rack to Vancouver, Canada!?!?
My concerns
-robustness of the fiamma rack vs. a hitch mounted rack.  Taking 2-4 bikes on a hitch mounted rack appears a more solid option at 100-110kmph on the highway.  Any comment as to the quality and reliability of long distance travel with the fiamma rack?
My concerns are:
-loss of clearance because to fit a hitch the attachment points are restricted by vehicle components, meaning a low mount position... therefore loss of clearance
-expense.  hitch mount likely a custom job + hitch mounted rack too
any thoughts, comments would be appreciated.  Particularly with respect to fitting and experience of fiamma rack on a toyota hiace
many thanks in advance
Andy
wernerk
Number of posts : 160
PostSubject: Re: Bike rack for super custom hiace   Tue May 20, 2014 12:30 am
Hi Andy,
by hitch, I am assuming you mean towbar? I have had a towbar fitted to my SC van and I bolt my bike carrier to it. From memory, the towbar was that for a standard Toyota Hiace. I remember that the cost was less than what was originally quoted to me as a standard towbar could be used instead of something custom made. I'm not sure of the part number though for the towbar.
I also use the towbar for towing a trailer  Very Happy
Hope this helps,
Werner
Number of posts : 191
PostSubject: Re: Bike rack for super custom hiace   Tue May 20, 2014 8:13 am
       I'm no expert but my thoughts are-
 If I was going to be driving on roads rough enough to warrant a suspension lift, I would worry about mounting a bike rack to the door of my van.  All the weight of the bikes will be on the sheet metal,  and four bikes weigh a fair bit,  especially since the outside ones will be exerting a bit of leverage on the frame of the rack.
 I have a Maxxraxx bike rack- it bolts to a towbar flange, which makes it pretty secure and also means the towball is free for a trailer (boats!).
 You might even consider putting a rack on top of a trailer and towing them. That would be very expensive to set up,  though, unless you already have one!
Maxxraxx: http://www.maxxraxx.co.uk
 I dare say they would ship to Canada, if they or an equivalent is not available locally.
 Have a look at the website to understand their selling points.  Even if you don't want one of these it may help you to cIarify what you do want!
They have a couple of handy features that are hard to find: you can fit extra brackets to other cars,  to make it easy to swap the rack over and, of course, you can still use the hitch!
» Buy your victim a nice bike, judge tells paedophile
» Custom Rank Title
» Custom Your Domain Name
