 Big confuse with a cooler switch(a/c switch)
worren
Number of posts : 8
Home City : laos
Registration date : 2014-05-01
PostSubject: Big confuse with a cooler switch(a/c switch)   Mon Jun 09, 2014 3:22 pm
I have searched a cooler switch (A/C switch) for my model in www.toyodiy.com and its part No. is 84660-95J01.
After I got the part,it confused me a lot.
Look from the new cooler switch ===> there are 4 pins on the upper row and 1 pin on the under row.
Look into the cooler switch socket ===> the 4 connector holes are on the under row and the one connector hole are on the above row. I mean the pins on the switch are opposite the holes on the connector. What's wrong?
PostSubject: Re: Big confuse with a cooler switch(a/c switch)   Tue Jun 10, 2014 9:49 pm
If you rotate the switch do they line up?
Yes remove the socket and rotate it.
No pull the lone one and replace into correct hole, most likely it is the live feed.
Let us know.
» Switch Accounts Widget
» Avatar Color Switch (Request done)
» switch-editor-mode-button
» Norden Christmas Light switch on...
» switch-editor-mode-problem-color-tags
