 Sliding door will not open
iamjo
Home City : london
Registration date : 2014-08-19
PostSubject: Sliding door will not open   Tue Aug 19, 2014 10:10 pm
One of the kids was attempting to very slowly and weakly close the sliding door, they got it shut but it will no longer open!
The light on the dash board comes on to tell me there is a door open, I presume its the sliding door........... When I press the door open button next to the steering wheel it makes a very quiet umff noise but does nothing. I can not open the door manually either. Grrrrr
I'v tried brut force, got the inner panel off and have no idea what to do.
Advice please.
PostSubject: Re: Sliding door will not open   Wed Aug 20, 2014 2:54 pm
Make sure the rear of the door is in and latched.
Try and open.
Still not moving, get inside and lie on the middle seats with your feet on the front of the door, with some one holding the handle in the open position give the door a sharp push with your feet.
Still not moving check it is unlocked using the key, the electrical contacts may not be engaged, and repeat above.
As you have the door card off, find the door lock motor and put 12v directly to it.
