 Large Fans below engine
jagged1
Number of posts : 31
Home City : Cabangan, Philippines
Registration date : 2014-03-14
PostSubject: Large Fans below engine   Tue Mar 10, 2015 12:36 am
There are 2 large fans on the bottom of my 1997 Hiace Super Custom 2L Turbo diesel that are mounted on what looks like a 2nd radiator. The fans aren't hooked up, and if I do, they will blow a fuse after a few hours. Looking on here, someone said that they had something to do with the aircon, but my aircon blows cold whether they are running or not. Any clues?
PostSubject: Re: Large Fans below engine   Thu Mar 12, 2015 5:55 pm
Yes one or both are coolers for the A/C. If you have 4WD I have heard that their could be a secondary coolant rad.
Take it to an A/C specialist.
Number of posts : 90
PostSubject: Re: Large Fans below engine   Fri Mar 13, 2015 6:01 am
Clive, I think a secondary coolant radiator, in addition to aircon, is correct. On a long hill climb that I travel frequently the two large fans can be heard cutting in even if the aircon is switched off. Mine is a 4WD model.
jagged1
PostSubject: Re: Large Fans below engine   Sat Mar 14, 2015 8:39 am
I took a second look and sure enough there is a second coolant rad tied in with the main one, then above that is the a/c condenser with it's own fan that turns on when the a/c is turned on. I wired in an old headlight relay to the coolant fan with a switch on the dash, now if it gets warm I can just turn the fan on manually.
» It's Foy not Hoy! Spurs fans abuse Olympic champion instead of blunder ref
» Millwall Fans......
» Have tweeting footie fans found Madeleine McCann?/Dailystar
» Psychotic Fans
» 400 Bad Request - Request Header Or Cookie Too Large
