 Tailgate light cluster removal??
Piedpiper
Number of posts : 13
Home City : Bedford UK
Model and year : 1992 Cruising Cabin
Registration date : 2013-03-18
PostSubject: Tailgate light cluster removal??   Tue Mar 10, 2015 4:37 pm
Hi all,
Hoping someone can tell me how to access the bulbs/remove the tailgate light clusters (not the ones on the body but actually on the tailgate itself)
Mine have never worked and one seems to fill up with water!
I can't see how to access the bulbs and/ or remove the whole light assembly...
1992 hiace cruising cabin.
Many thanks
P
View user profile http://www.etaenergy.co.uk
PostSubject: Re: Tailgate light cluster removal??   Thu Mar 12, 2015 5:47 pm
You need to remove the trim panel from the inside, bulbs are easy to get at. If you want to remove the lights to seal them up, a few hundred nuts hold them in in!
Piedpiper
PostSubject: Re: Tailgate light cluster removal??   Fri Mar 13, 2015 5:02 pm
Hi Clive,
Many thanks, they didn't make that easy then!!!
I'll have a look over the weekend and see if I ca work it all out😎😎
Pete
Ace MM
Number of posts : 43
Home City : California USA
PostSubject: Re: Tailgate light cluster removal??   Wed Oct 12, 2016 10:32 pm
How about for a 1990?
Have the interior trim panel off but still can't tell how to remove them? Suspect
» 4th Light Anti- Aircraft Regiment RCA
