 Passenger side brake light on constantly
muzzat
Home City : Stirling
Model and year : 1994 LH113 Dreamhouse/Noppo conversion 2.8L
Registration date : 2012-07-13
PostSubject: Passenger side brake light on constantly   Fri Nov 27, 2015 3:38 pm
I woke this morning to find the passenger side brake light on constantly, even with the ignition off.  The driver side brake light works perfectly normally, so it's not the brake light switch.  Any ideas?  It's a '94 2WD Hi-Ace.
Thanks in advance for any advice.
Number of posts : 189
PostSubject: Re: Passenger side brake light on constantly   Sun Nov 29, 2015 8:15 am
First thing I would do is look for a wiring fault at the light cluster.
Does the driver's side light work OK?
I would expect that if it's only affecting one side then the problem will be a short or bad ground in the cluster itself or the wiring specific to it...
rubythursday
Number of posts : 44
Home City : York
PostSubject: Re: Passenger side brake light on constantly   Sun Nov 29, 2015 1:27 pm
Do you have a trailer socket fitted? If so check for contamination/shorts in the back of the socket.
drewglasgow
Home City : Glasgow
Registration date : 2014-04-30
PostSubject: Re: Passenger side brake light on constantly   Sun Jan 10, 2016 11:36 am
Turned out to be a broken spacer on the brake pedal arm, that sits between the arm and the switch that causes the brake light to come on, there was a red herring in that it was only one brake light as other one had popped over night whilst burning away.
» Two women 'caught trying to smuggle dead relative on to passenger jet at Liverpool airport'
» Fan fury as Rose shows thorny side
