 Filter or Strainer
Guest
Guest
PostSubject: Filter or Strainer   Mon Dec 07, 2015 4:57 pm
I have a new to me 1990 HiAce. Chassis LH107G. It only has 78,000KM on engine. Running great except I am leaking a bit of transmission fluid. 3-5 drops each day that it is driven. 99% of the time it shifts quietly and smooth although sometimes when it is hot it shifts at a different RPM. Maybe a throttle body cable adjustment is needed?.
To date I have changed all fluids and filters in the van but have not yet done the tranny. Wanted to do that this week but without a manual and after several hours of web searches I am not sure if I need both a gasket and filter or is does this van have a strainer that can be cleaned. Don't want to tear into it before I have the parts needed to finish the job.
Thanks in advance for your input.
PostSubject: Re: Filter or Strainer   Tue Dec 08, 2015 9:41 pm
My 1994 one had a strainer, gasket was sealant so that is what I used.
Not much to clean out and probably could have not bothered, but you don't know until you look.
Have you changed the fluid?
Guest
Guest
PostSubject: Re: Filter or Strainer   Wed Dec 09, 2015 5:00 am
I changed the fluid today Clive. Didn't mess with the filter. I'll report back in a few days after getting some drive time. Thanks for the reply.
PostSubject: Re: Filter or Strainer   Wed Dec 09, 2015 6:55 pm
Fingers crossed.
Just noticed where you are, hope you have a heated garage to work in.
Filter or Strainer
» Blood Red DMD filter added to Sopranos....
» better forumotion spam filter
» Avatar grayscale filter on hover
