 Failed charging unit...
Number of posts : 189
PostSubject: Failed charging unit...   Sat Feb 20, 2016 9:54 pm
     I've lost a terminal from the charging splitter on my camper.  It's a '94 and the unit is pretty basic: just a diode pair with heatsink.
 There are better alternatives available now. Either drop-in replacements with Schottky diodes or FET based ones... or I could change to a split charge relay (vsr?).
Anyone any advice?  I'm thinking the Schottky ones look sensibly priced and will be an improvement on the old setup but would I notice the difference if I spent the extra for FETs? A voltage sensitive split charge relay looks like a decent alternative but I'd prefer to have a solid state one than electromechanical... Are they available?  Expensive?
Thanks!
Number of posts : 586
PostSubject: Re: Failed charging unit...   Mon Feb 22, 2016 7:14 am
I think the voltage sensing charge relais are cheaper, and they don't have the voltage drop-off.
And I think they will last quite long as well. I'm also using a relais.
I don't think you would find such a thing in solid state, it would also make it expensive, but I could be wrong.
PostSubject: Re: Failed charging unit...   Thu Feb 25, 2016 7:51 am
   Thanks for the advice, Hiace4wd. I'm keen to stick with a solid state unit, though, rather than introduce something electromechanical. Would be nice to improve on the old diode-pack, though.
While researching, and trying to find a price for a solid state split charge relay, I came across a FET based charge splitter on eBay for sensible money. It's one of these:
https://www.victronenergy.com/battery-isolators-and-combiners/argo-fet-battery-isolators
...and looks like it should do what I want.
Will feed back in a while, once it's in and working.
PostSubject: Re: Failed charging unit...   Thu Feb 25, 2016 8:31 am
Ok that sounds good. I have a Victron Solar charger and I think the Victron products are really nice.
That solution is still not as cheap as a voltage detection charge relay, but I guess the price is reasonable for what you get. And almost no voltage loss so that's good.
I just bought a simple 200A relay for 10 euro that I need to hook up automatically (to alternator). I use it manually now, and it works quite well for such a cheap solution. But most of the time I don't use it, because I have a huge 175W solar panel. That always keeps the battery full (at least in holiday time) even though I have a fridge with small freezer on board.
pauly1972
Home City : sunderland
Registration date : 2016-03-19
PostSubject: Re: Failed charging unit...   Sun Mar 20, 2016 5:15 pm
Hi spanner do u have a ecu diagram for a 1996 hiace camper 1kzte it's a early one with a single 26 pin plug many thanks paul
» Minister: Tracey Fay was failed by the State
» Unit markings on my snider...?
» Inside the Biological Countermeasures Unit - Interview with a special agent takes you inside the Biological Countermeasures Unit
» Joint Personnel Support Unit (JPSU) is in disarray
» LEANNE CHAMBERS
