 By pass Heater Cores
Sagsagy
Home City : nz
Registration date : 2016-07-08
PostSubject: By pass Heater Cores   Fri Jul 08, 2016 12:26 pm
Hey
Having Trouble with heaters in Van
Would like to by pass the system to solve problem
Front and Rear Heater core.
Has any one done this before ?
where does the heater line leave and return ?
PostSubject: Re: By pass Heater Cores   Fri Jul 08, 2016 8:19 pm
Rear heater feed/return is drivers side underneath rear wards of the air filter.
Front I can't remember but would again be underneath and up the front.
Are they leaking?
Sagsagy
Home City : nz
PostSubject: Re: By pass Heater Cores   Fri Jul 08, 2016 10:33 pm
I dont want a Rear heater.
The Front is Leaking have tryed stop leak products but they know good.
iv No time or money for a new heater core at the moment.
Thanks for the Help
Number of posts : 583
PostSubject: Re: By pass Heater Cores   Sat Jul 09, 2016 6:51 am
For front heater there are two hoses running from the left side of engine to the front behind the bumper.
You can see them when you lay under the car from the front bumper side.
One hose already closes off with a cable if you disable heating. You will see that mechanism as well there.
The return line you would need to srop yourself.
I wouldnot by pass it, I would just close it. Because that would give you slightly better cooling, more coolant going to radiator.
» Did HR 4646 Pass? It's another obastarda sneaky tax.
» By pass confirmed screen
» pass word error Not login
» Farrah Fawcett RIP
» The McCanns and The Polygraph
