 How to make the seats rotate differently
Number of posts : 600
PostSubject: How to make the seats rotate differently   Fri Aug 05, 2016 11:03 pm
So, the two-seat chair in the SC rotated the wrong way around, so I took it out and took it to bits to investigate.
Interestingly the seat base base and support are bare steel, no paint at all. So there were some rusty bits I painted in Kurust.
So you have options.
Just flipping the seat:
This is the easy option and just makes the seat turn the right way, but still limits it to 180 degrees.
You need to get rid of the plastic and look closely at the runners under the seat. There are four black welded bolts that have nuts that hold the whole swivel+seat onto the runners.
You will also need to release the runner release spring lifter (activated by the control under the front of the seat), turn the seat so that the flat lines up with the slot and it unhooks from the cup.
BTW if you want the seat base out of the way, it's held on with 4 medium yellow bolts, fold the back down horizontal and it will then lift off.
Turn the seat so you can see the back. In the back on the swivel is a slot - that slot allows you to access all the nuts. Undo the runner bolt nuts to lift the seat off. Ironically this is a great deal easier if you have already made it rotate 360 degrees (see next section). There is also a gap on the inside of the front if you leave it at 180deg.
When you do this realise that when you lift the chair off the runner bolts two of the internal guides will now be loose in the swivel and need poking a bit to line them up if you disturb them - to fit back onto the runners again.
Making it turn round and round
At 180 degrees each side of the swivel is a locking slot. As you will see, the slots are biased to one side, you will need an angle grinder and some care to trim them to become symmetrical, then the seat will swing any way and still lock in the two positions. When you do this you should probably protect the gap in the swivel with some masking tape, as the bits will go down and cause problems.
Try not to grind them all off in one go as you'll cook the plastic in the swivel. Toyota thoughtfully doubled up the metal at this point so it needs a lot of grinding. I'd recommend you do this outside and make sure the sparks go away from the seat material and protect the base frame paint with a cloth. It's also possible the cloth will catch fire so maybe dampen it.
Being really keen and re-greasing the swivel
If you want to do this, use the slot in the back of the swivel to undo all 8 nuts, but leave the lone 2 on until you get the chair out to somewhere you can work on it. The lone 2 are the only 2 not bolted to the runner frame/base, they just hold 2 guides in the swivel.
I used moly grease - try to use a grease good at sliding, as there are no rollers, it's plastic, grease and metal bearing directly on the outer of the swivel. Lots of blue paper roll is good at cleaning out the old grease.
Warning: Re-assembly is fiddly and needs another person. There are 4 guides in the swivel, 2 are held by the lone 2 bolts (each guide goes from a runner bolt to a yellow bolt - i.e. they span the corners. The other 2 are loose, and not held in until you bolt it to the runners again. I found it easier for a person to hold the seat so the swivel was the way up it is in the car, and plug the base/frame in from underneath, then transfer the whole assembly to the floor, carefully tilt the seat up fully again and then pop the nuts on to hold it all together.
Other notes
Once the seat base is off, this is an excellent time not just to degrease and paint the bare metal, but also to clean the seats with any valet products etc, as you can reach all the fabric.
Number of posts : 204
PostSubject: Re: How to make the seats rotate differently   Sat Aug 06, 2016 9:50 am
I like Cool but I honestly thought uou could just unbolt from the floor, turn the base 180 deg and bolt back down, nothing ever simple these days Very Happy
PostSubject: Re: How to make the seats rotate differently   Sat Aug 06, 2016 10:21 am
mickB wrote:
I like Cool  but I honestly thought you could just unbolt from the floor, turn the base 180 deg and bolt back down, nothing ever simple these days Very Happy
Ah yes, the frame/base is keyed into the corrugated floor so you can't do that LOL. I assume the idea of that seat rotating the 'wrong way' was a safety 'feature' to stop passengers travelling with it sideways.
Assuming you can get at all 4 17mm yellow nuts inside the swivel cage and unhook the runner spring lever; the easy, intrusion free method is to carefully pick it off the runners and pop it down 180 degrees the other way. Be prepared for oil and grease so don't dump the free seat on your carpet.
Removing the base cushion first makes the chair considerably lighter and access much more likely....
One advantage of taking both seats completely out is the ability to hoover the carpets underneath.
PostSubject: Re: How to make the seats rotate differently   Wed Aug 10, 2016 5:25 pm
Step 2:
Ok, so now the seat rotates 360 degrees it's wonderful!
....Or so it would seem - until one sticks them back into the Hiace and turns them. So, the pods where the seat belts live hit the side wall where the heater controls are, so you cannot in fact turn your super new seat yet, because you need to move it exactly 25mm away from the side so it will just clear it.
I'll post photos, but essentially it involves modifying the base pressing that the runners rest on, so the procedure is:
1 ) Take out the chair by unbolting the base from the floor.
2 ) Undo the 6 bolts that hold the runners onto the base.
3 ) Take the base and grind off the welds that hold the 13mm spacers on - these are in the way when you are 25mm over.
4 ) Measure 25mm over and drill some 11mm holes in the bits of the base that live next to the side of the van.
5 ) Cut some semi-discs out of the other base holes, as 25mm over from them is the metal edge.
6 ) Find some 2.5mm galvanised building metal strips.
7 ) Drill some 11mm holes so when you screw the base back in, this bar fits over the two holes.
8 ) Find some 12.5mm ply and cut out two strips (35mm + 42mm x 55mm) and drill 11mm holes.
9 ) Assemble it all and check it bolts to the floor. Cut 10mm slits in the carpet.
then...
10) Bolt the base back onto the runners
11) Bolt the seat back onto the floor with the wood and strips. Ensure the base is on the metal floor - not the sound deadening or carpet, and the wood is in the 2 grooved bits of the floor (where the old 13mm metal bits you ground off were).
Job done!
Tips:
To drill 11mm holes in metal, start with 3mm, then go to 5mm, 7mm, 9mm and then 11mm and it will be a) possible and b) in the right place.
Note:
This may be incompatible with the continued usage of the single swivel chair. It is however, reversible as the old holes are still there in the seat base.
jpg images
» Minister Murdered TV Make-Up Artist Wife
» Name That Book! Make us laugh!
» Mirror Sky Preview - Maddie Cops to Make First Arrests
» Make sure that you use the correct Email address
» How to make colored signs
