 Alternator removal
Roop
Home City : Llandrindod Wells
Registration date : 2016-08-17
PostSubject: Alternator removal   Wed Aug 17, 2016 8:32 am
Have a hiace super custom 1996 - Alternator stopped working - dodgy batteries cause it to fail I think! Need to remove and replace diodes I think? However complete novice at this. Looks like there's an air condition pump above it and looks like theres three belts to come off. Are there any manuals step by step guides or you tubes of removal by anyone?
Number of posts : 582
PostSubject: Re: Alternator removal   Wed Aug 17, 2016 1:03 pm
I don't have AC in it so I don't know how crammed it is in there, but can't you replace diodes and/or brushes while it is still in there? So without removing it?
Anyway, I don't think batteries can damage an alternator. It is only possible to damage batteries with a bad alternator (broken regulator giving a very high voltage for example)
In this case, if you are certain that your alternator is broken, it is probably because it is old. And you may think your batteries are dodgy because they were not charged properly by your alternator.
PostSubject: Re: Alternator removal   Wed Aug 17, 2016 9:22 pm
Drivers seat out, drivers floor out. Alt can be removed after removing drive belt by adjusting the tensioner. No enough room to fit diodes in situ.
Number of posts : 537
PostSubject: Re: Alternator removal   Wed Aug 17, 2016 11:05 pm
Diagrams can help working out where things go.
http://jp-carparts.com/toyota/partlist.php?maker=toyota&type=711140&cartype=136&fig=1903
If yours is the 3L Diesel 1KZTE engine it's the same as in the Hilux, there are more likely to be youtube videos of those than for the less popular Hiace.
BTW if you do have to push the A/C pump out of the way keep the pipes connected, it has to be drained and filled by an AC expert. I'd guess you could have a go from underneath but I haven't looked so I have no idea if that is possible.
bordurat
Home City : South Shore Mtl
Model and year : 1992 super custom limited lh107w
Registration date : 2016-09-07
PostSubject: Re: Alternator removal   Thu Sep 07, 2017 8:00 pm
Alternator removal
» Cipriano Case: Psychic Prosecution Lawyer requests removal of the President Judge Henrique Pav„o
» So, There IS such a thing as "TREE LAWS!" (on Public Parkways!)
» Ad removal?
» Removal of adf.ly
» Forumotion Footer Copyright Links Removal
