 Lower suspension
Danthevanman
Number of posts : 11
Home City : Melbourne
Model and year : 1996 Hiace super custom living saloon ex 3.0lt
Registration date : 2016-07-09
PostSubject: Lower suspension    Sun Aug 21, 2016 12:49 am
Ok guys, I'm going to lower my SC a little so it
Doesn't look like a 4wd. Front is easy. But how do
I get the rear springs out?
Number of posts : 582
PostSubject: Re: Lower suspension    Mon Aug 22, 2016 11:01 am
Do you really want to remove them?
I think it would be sufficient, to get the axle off the leaf springs (while keeping the leaf springs still assembled, with the van jacked up), by loosening the U bolts.
And then add some spacers between leaf suspension and the axle. This could be a piece of metal with a whole in there for the centerbolt.
For this way, you're going to need longer centerbolts and longer U bolts.
By removing a leaf you also lower the spring rate, so I don't think it is recommended.
If you think the van's rear suspension is to hard now, and you're never carrying anything, then maybe you can remove a leaf. But otherwise, I think you're going to hear the wheels hit your fender from time to time.
Number of posts : 537
PostSubject: Re: Lower suspension    Mon Aug 22, 2016 8:05 pm
Are they leaf or coils on the back?
Mine are coils, but I've seen lots have leafs..
Number of posts : 184
PostSubject: Re: Lower suspension    Tue Aug 23, 2016 10:27 am
Mine has coils and I can't find any lowered after market anywhere so the grinder will come out and a coil or two with be lopped off
Danthevanman
PostSubject: Re: Lower suspension    Wed Aug 24, 2016 12:53 am
It's a coil spring rear end. Toyota 5 link suspention.
I'm getting the standard springs compressed slightly.
Lower suspension
» Sion Jenkins refused compensation - IMO he's Innocent....
» Kate's "Epilogue"
» Move the search bar lower
