 Correct ATF oil for 2.4l te SC
Number of posts : 221
PostSubject: Correct ATF oil for 2.4l te SC   Tue Aug 23, 2016 10:41 am
I will be having mine serviced next week, I have the filters and engine I just want to check on the auto box oil, is it standard ATF and can anyone tell me the capacity of the box when drained too
Also, having a nose round the forum I have found the previous owner of my van, Simongod from Liverpool, he appears to have emigrated to Hungary but searching hi profile questions has brought up some good notes and info on the van I now own
PostSubject: Re: Correct ATF oil for 2.4l te SC   Tue Aug 23, 2016 5:19 pm
Just a drain from the sump about 4-5 litres. New sump filter i.e. removing the sump 5-6 litres.
1-2 litres will stay in the torque converter and 0.5-1 in the cooler lines.
Any ATF will do.
PostSubject: Re: Correct ATF oil for 2.4l te SC   Tue Aug 23, 2016 7:36 pm
Any ATF will do.
Thanks clive
Number of posts : 689
PostSubject: Re: Correct ATF oil for 2.4l te SC   Tue Aug 23, 2016 10:16 pm
Is it easy-ish to replace the AT filter?
Any idea of how much a Toyota OEM one may cost?
PostSubject: Re: Correct ATF oil for 2.4l te SC   Wed Aug 24, 2016 10:20 pm
Easy but messy, 24 bolts ish, There is a lot of fluid in the sump that you will spill!
Don't remember how much, sealed with non setting sealent.
» Factually and historically correct and verifiable.
» Guide to British-made Aluminum Mess Tins (1936-1940)
» Make sure that you use the correct Email address
» Correct the formatting of the new editor in source code mode
» Unbold name
