 Lowering amount on the front and back
Go to page : Previous  1, 2, 3
Number of posts : 529
PostSubject: Re: Lowering amount on the front and back    Sat Oct 28, 2017 7:19 pm
Hmm - are RAV4 springs that expensive? 38 a pair here:
http://www.ebay.co.uk/itm/NEW-CD-AUTOPARTS-REAR-COIL-SPRINGS-BAGGED-PAIR-TOYOTA-RAV-4-MK2-2000-2005/252953901833?fits=Model%3ARAV+4&hash=item3ae53a3b09:g:VB8AAOSwcdRY91or
You'll need to measure them, but at that price if they were the right diameter I'd probably just buy them to try. If you can get an old spring out of the HiAce then I'd go to a place that stocks RAV4 springs and compare them on the bench, you'll soon see if they are a plausible alternate just by laying them out side by side.
Number of posts : 183
PostSubject: Re: Lowering amount on the front and back    Sat Oct 28, 2017 7:51 pm
every rav4 I searched gave me a lot more per spring Shocked must be searching wrong lol
trouble is I don't want to get some a they be no good just to get a baseline on rav4, I've got my baseline on the Hiace ones, I'm considering a one off pair made as there seems to be a few spring companies around that will do a set
View user profile Online
PostSubject: Re: Lowering amount on the front and back    Sat Oct 28, 2017 8:19 pm
Agreed, no one wants to buy useless springs, although they are cheap for a try and can be sold on.
I'd get the good/uncut back spring out and measure the diameter, length and thickness of the steel, then head to a place with a few RAV4 springs and compare them.
Then choose one that identical diameter & thickness but slightly shorter and use that, e.g one about 50mm longer at free length will be under 25mm on the van I reckon.
PostSubject: Re: Lowering amount on the front and back    Sun Nov 05, 2017 3:49 pm
Rear end is done eventually, don't ask, should have cut more spring out but that's for another day, lenso alloys on rear to with 225/50 16 tyres, got to wind some more out of the front torsion bars to drop a little more and switch tyres to new alloys and suspension done, next is the leisure battery job,
Now, how can I host photos as photo bucket charge the earth too
PostSubject: Re: Lowering amount on the front and back    Sun Nov 05, 2017 5:18 pm
Sounds good!!
Put photos here for free:
http://postimages.org/
PostSubject: Re: Lowering amount on the front and back    Sun Nov 05, 2017 7:20 pm
Cheers for that GPW
PostSubject: Re: Lowering amount on the front and back    Sun Nov 05, 2017 7:59 pm
Height looks perfect to me.
To slam it 'properly' you end up running on the bump stops, no use to anyone Smile
Did you add the window stickers or are they original?
PostSubject: Re: Lowering amount on the front and back    Sun Nov 05, 2017 8:12 pm
Window stickers are all my idea, might take some off, bit too much maybe, I do wish I'd taken another half coil out though, just to loose that gap I still have, bump stop is about 25mm from the axle but they are easy enough to cut down
PostSubject: Re: Lowering amount on the front and back    Sun Nov 05, 2017 10:34 pm
I quite like the stickers, some looked japanese so I wondered if they came with it!
25mm to the bumpstop (unloaded?) is not great - how does it drive?
Mine have about 5mm and it's not enough, I'll probably put 20mm solid rubber pads under the springs.
What you may find is that bigger diameter wheels and tyres fill out the arches better, IIRC there was a car (Landrover discovery?!?) that had compatible wheels but I can't quite recall what it was.
PostSubject: Re: Lowering amount on the front and back    Mon Nov 13, 2017 3:49 pm
PostSubject: Re: Lowering amount on the front and back    Mon Nov 13, 2017 4:02 pm
Very nice Mick, just need a big shiny tailpipe now!
As it's coming up to salty road time you may wish to consider waxoyling inside the panels and doors if it's not been done. Not sure how to get it to flow in this weather but it's worth doing as these JDM vans are not waxed like the UK spec stuff is.
PostSubject: Re: Lowering amount on the front and back    Wed Nov 15, 2017 7:32 am
I've already splodged a load of underseal under it, covered most of the floor, the bottoms of the front doors are shot so will be a body project for next year, need to get the leisure battery install done now then have a better side exit exhaust made up, that is just a slash cut cherry bomb, straight of the down pipe, does have an awesome turbo whine when running Very Happy
PostSubject: Re: Lowering amount on the front and back    Sat Nov 18, 2017 9:49 pm
Well I know why the front won't drop any more, I've bottomed out on the lower bump stop, so wheels off and trim the sh*t out of the rubber next
PostSubject: Re: Lowering amount on the front and back    Sat Nov 18, 2017 10:49 pm
Ah yes, my front was just resting on the rather-too-well-used bump stops so I raised it. The ride was terrible!
PostSubject: Re: Lowering amount on the front and back    Sat Nov 18, 2017 10:55 pm
Raised the rise height???? Surely not, the lower the better remember 😂 I'll be cutting vast chunks from both front bumps
PostSubject: Re: Lowering amount on the front and back    Sat Nov 18, 2017 11:11 pm
Very Happy
I recall that the bump stops are pretty small - unless I missed another set somewhere else. I got the impression that any thinner and they'd be a 'crash crash' instead of a 'bump bump' sound. Take some pics when you're down there!
Maybe you could have the hubs modified to make it sit lower?
PostSubject: Re: Lowering amount on the front and back    Sun Nov 19, 2017 5:42 pm
That's the lower bump stop pretty much on the arm
PostSubject: Re: Lowering amount on the front and back    Sun Nov 19, 2017 7:48 pm
Ah yes, they are the ones I saw, I thought they looked tiny for such a large van, maybe the shocks have stops built in.
Careful you don't bend something or stress the wheels too much if there's a big bump you meet, I'd take it easy at first and see what you think of the ride!
PostSubject: Re: Lowering amount on the front and back    Tue Nov 28, 2017 12:25 pm
I really really need to trim that bottom one Shocked its a bit harsh over certain sleeping policeman bounce bounce in the cab
I haven't had chance to jack up again but from memory the plate that the lower bump hits looks like it does nothing but be a stop for the bump stop, so trimming the rubber plus adjusting [re: hit hard with hammer] will give me more movement on that lower arm,
What do others think ?
Page 3 of 3Go to page : Previous  1, 2, 3
» Balconing is back on the Baleares
» Gary Glitter - it's good to be back?
» Maybe sitting in the back of the Bus isn't a bad idea after all...
» Duke of Edinburgh back to his old self
