 Rear Shock Removal - How To
Number of posts : 186
PostSubject: Rear Shock Removal - How To    Wed Sep 14, 2016 7:35 pm
Hey up all, for my next plan and part of the lowering job sion I have found whilst net searching that VW T4 shocks will fit to the Hiace, I knew my dub background would come into play with this lol, I had a quick look underneath tonight and fronts are a doddle, the rears though I can't see how you get to the top nut on the shock, it's through a cross member but I can't see how you gain access to the top nut???
PostSubject: Re: Rear Shock Removal - How To    Sun Sep 18, 2016 8:28 pm
Did not do a Hiace but did a Townace you get to them from in the cabin had to take rear seats out to lift the carpet hope it is the same.
Number of posts : 583
PostSubject: Re: Rear Shock Removal - How To    Mon Sep 19, 2016 8:19 am
Well, I don't know if the coil spring Hiace is different from the Leaf suspension Hiace... But in my leaf suspension Hiace the floor is completely closed, there are no holes in it. So I would expect anything being done from inside.
Do you perhaps have a picture?
PostSubject: Re: Rear Shock Removal - How To    Mon Sep 19, 2016 11:05 am
It does look like I go from inside as there is no way you could get a spanner above the shock bracket as its so close to the floor, haven't a photo but will look closer inside, my plan is to fit VW T4gas shocks as they appear to be a straight swap and can be obtained a lot easier that the Hiace shocks
Number of posts : 539
PostSubject: Re: Rear Shock Removal - How To    Wed Sep 21, 2016 5:20 pm
Maybe there's a rubber grommet access from the top?
Can you measure/compute where the top is - from above and look under the carpet?
That will tell you what they intended, I've found the HiAce is easy to maintain as long as you work out how they intended you to get to stuff!
PostSubject: Re: Rear Shock Removal - How To    Sun Sep 25, 2016 4:09 am
go in from cabin lift carpet and covers you will find the top nut I've done mine and was easy as.
Very Happy
cheers dave
PostSubject: Re: Rear Shock Removal - How To    Sun Sep 25, 2016 9:30 am
Cheers dave
» Daily Express.....MADELEINE SHOCK, NEW LOOKALIKE VICTIM SNATCHED FROM HER BED
» Cipriano Case: Psychic Prosecution Lawyer requests removal of the President Judge Henrique Pav„o
» So, There IS such a thing as "TREE LAWS!" (on Public Parkways!)
» One Woman in India dies every hour due to the dowry system
» Ad removal?
