 Rear crank oil seal leaking, how big a job?
Number of posts : 184
PostSubject: Rear crank oil seal leaking, how big a job?    Mon Oct 03, 2016 8:06 pm
Looks like I can't put of the inevitable and I'm going to have the replace the rear crank seal, 2.4 td with auto box
I don't think itll be too bad but just asking if any others have done the same job?
PostSubject: Re: Rear crank oil seal leaking, how big a job?    Mon Oct 03, 2016 9:43 pm
Gearbox out TC off if it did not come off with GB  - make sure you fit it to the gearbox before refitting both. Flexplate or flywheel and then I think there is a seal holding plate.
Not very technical, bolts will be done up tight and gearbox weighs a bit, if you have a helper not hard at all.
PostSubject: Re: Rear crank oil seal leaking, how big a job?    Tue Oct 04, 2016 6:50 am
Thanks Clive, its as I thought then, nowt too dramatic
» Defense Files New Motion to Seal Jail Records
» Deck Profile: The Seal of Orichalcos
» Modified Leather Jerkin
» Rear admiral apologizes to Indigenous recruits for sailor's 'war cry' insult
