 Removing the injectors
KIWI DAVE
Number of posts : 66
Home City : EASTBOURNE
Model and year : SUPER CUSTOM 3.0LT TDI 4WD
1995
Registration date : 2010-01-03
PostSubject: Removing the injectors    Thu Nov 03, 2016 4:53 pm
Hi Guys, hoping for a little advice on how easy/difficult it is to access the injectors for removal. Typically the two rear injectors are hidden towards the back and look hard to access. Does the driver seat need to come out and what else needs removing to access them. Any advice is greatly appreciated. Cheers Dave
Number of posts : 658
PostSubject: Re: Removing the injectors    Thu Nov 03, 2016 7:30 pm
Hi Dave,
I'm not sure because I have a different engine. But the driver seat is easy to remove, and so is the plate that is under there, it is around 8 or 10 bolts.
Then there should be a plate above the transmission, but I doubt it will allow you the injectors.
KIWI DAVE
1995
PostSubject: Re: Removing the injectors    Fri Nov 04, 2016 8:05 am
Cheers for the reply, I have taken the drivers seat before, but before doing this I really wanted to know if this was necessary and that it would ultimately allow me to remove any other parts that are in the way of accessing the two rear injectors. Regards, Dave
PostSubject: Re: Removing the injectors    Fri Nov 04, 2016 8:30 am
Ok well I cannot confirm that for you, since I don't have the same engine. But the seat and plate below it, can be taken out pretty quickly.
» Removing Current Time/Date from PHPBB 3
» phpBB2 - Needing help moving PM icon to side profile and removing vacated row
» removing-the-legend-s-bold-and-italic
» Better way to delete emoticons.
» Removing search box
