 Air Con Fan
qpv8evo
Number of posts : 22
Registration date : 2008-01-25
PostSubject: Air Con Fan   Mon Feb 18, 2008 8:50 am
The mystery fan noise that comes on with my ignition is my aircon fan,I found the relay and pulled it out and hey presto it stopped.Im not sure why my aircon fan relay has constant ignition fed live to it,I cant seem to turn it off,when I bought the vehicle it didnt do this but after a few days it started to come on all the time.any ideas????
Gareth
zoochy
Home City : Tropical Canada
Model and year : LH107G 1991
PostSubject: Re: Air Con Fan   Mon Feb 18, 2008 8:09 pm
qpv8evo wrote:
Im not sure why my aircon fan relay has constant ignition fed live to it,I cant seem to turn it off"
Did you determine this w/ a voltage tester?
If you switch the Air Con on does a second terminal become hot? Or the hot become not-hot?
If nothing changes when you flick the switch then your switch is not functioning correctly. If there is a change in what's hot and what's not, then you have a faulty relay.
Good luck.
qpv8evo
PostSubject: Re: Air Con Fan   Mon Feb 18, 2008 9:11 pm
Will check in the morning, bit cold and dark at the minute.
Gareth
Air Con Fan
