 Dash indicator lights flickering
x_ozzy_x
Home City : Philippines
Registration date : 2016-11-19
PostSubject: Dash indicator lights flickering   Sat Nov 19, 2016 10:11 am
Hi guys,
Ok, just found out after a long trip yesterday that oddly flickering of lights on my dashboard (battery, tbelt, wiper water etc.) some times it will not show at idle but when i revved it up at higher rpm (say 2000rpm), the flickering of lights shows up. then it will vanished at 3000rpm
Any ideas what caused it? thanks alot
Number of posts : 90
PostSubject: Re: Dash indicator lights flickering   Sun Nov 20, 2016 10:37 pm
The symptoms appear similar to a problem I had. The auto electrician diagnosed it as an alternator fault which he then rebuilt. The fault reappeared a short time later and was traced to the new brushes not seating correctly. So for you it may just be a brush fault rather than a rebuild.
Number of posts : 648
PostSubject: Re: Dash indicator lights flickering   Mon Nov 21, 2016 8:10 am
Something with the alternator, or a bad mass/ground connection somewhere.
Number of posts : 191
PostSubject: Re: Dash indicator lights flickering   Wed Nov 23, 2016 11:27 am
I've seen this with bad ground connections. My issue was with the split charging system, where the ("factory") diode charge splitter lost a connection due to corrosion, then subsequently I had a loose connection on the electronic charging controller I replaced that with.
The loose connection resulted in loss of charge which showed up as this symptom. Could be that poor charging from another source would cause the same effect but that bad ground was a relatively easy fix!
PostSubject: Re: Dash indicator lights flickering   Wed Nov 23, 2016 12:42 pm
yeah but you would have to find that bad ground connection first Smile
I would also suggest to take of the battery connections/clamps and clean them, to see if it helps.
I think there is also a ground cable from engine block to the body? I haven't checked this for the Hiace, but that could have bad connection. And perhaps clean the alternator connector?
