 lights issues
Gus_34
Home City : Abbotsford B.C. Canada
Registration date : 2016-12-28
PostSubject: lights issues   Wed Dec 28, 2016 4:13 am
My 91 Hiace suddenly has no rear lights. Brake lights and signals are fine. I have no instruction book or the likes. where do I locate the likely culprit......Thanks
Number of posts : 648
PostSubject: Re: lights issues   Wed Dec 28, 2016 3:41 pm
You have checked the light bulbs? And checked your fuses?
Number of posts : 143
PostSubject: Re: lights issues   Sun Jan 08, 2017 8:13 pm
hi my SC switches do not illuminate when driving with lights on as they are all at this state I assume it is a sercuite problem rather than just bulbs in the switches any Ideas.
Number of posts : 647
PostSubject: Re: lights issues   Sun Jan 08, 2017 11:28 pm
Fuse box next to the drivers feet?
PostSubject: Re: lights issues   Mon Jan 09, 2017 10:08 am
Hi any idea which fuse hard to get at (geriatric with back problems) fuse makes sense as someone has fitted switch for rear fog not very professional job.
PostSubject: Re: lights issues   Mon Jan 09, 2017 12:13 pm
There may be a fuse layout on this site, but I think your best bet is to take to cover off because there should be a map of the fuses under there.
The way to get to it is to open the door wide, move the seat back all the way and stand on the ground outside.
A powerful LED torch will help show up the broken fuse without having to remove them all to check as the fusible bit should be visible in the middle of each fuse.
It's not a good position - you are right.
Let us know how you get on..
PostSubject: Re: lights issues   Tue Jan 10, 2017 8:46 pm
hi looked at fuses no fuse allocated to switches all fuses working still baffled
PostSubject: Re: lights issues   Tue Jan 10, 2017 11:45 pm
So are none of the fuses in the panel blown at all?
There are a couple of big fuses next to the battery +ve terminal, might be worth checking there too.
Can you list all the lights that don't work and do work?
I.e.
Indicators
Reversing
Brake
Tail
Fog
Headlamps
Sidelights
Dash lamps
Instrument cluster lights.
Interior lights
And does everything else work?
PostSubject: Re: lights issues   Wed Jan 11, 2017 10:43 am
Hi nearly everything electrical is working just the three switch lights near heater controls they work but doe not illuminate not good driving in the dark. PS have now got ECT switch to eliminate the top just pops of and reveals a bulb moved it now it works, bulb in side of hazard switch is dud 7.00 from Toyota 2 for 10 on ebay fingers crossed 2 down 1 to go thanks for the interest we live and learn.
lights issues
» #1375 Chatbox issues
» [Only Topic] Notifications, Loading, Chatbox, Servimg and Tagging Issues
» [Only Topic] Forumotion server issues/outage
» Malware Issues Have Not Been Resolved
