 Sc will not start
Number of posts : 98
PostSubject: Sc will not start   Fri Jan 13, 2017 3:08 pm
Hi my sc will not start fires a few times then stops will not fire again for a while then does same again , with ignition on there is a constant ticking sound from injection pump suspect stop solenoid , power to heater plugs with ignition on goes out when engine stops had same problem a few weeks back. any ideas please.
PostSubject: Re: Sc will not start   Sat Jan 14, 2017 1:28 pm
Sc will start after much head scratching (and trawling through the internet) I decided to go back to the basics. First ensure battery is fully charged (put it on charge for several hours) this gave time to check everything fuel fuel filter glow plugs air leaks vacuum pipes etc. Tried starting again fires up first time and running as normal, conclusion new battery required, sub zero weather will kill poor batteries voltage drop when cranking must interfere with sensitive electronics, sensors etc resulting in failure to start. This could have been very expensive if one starts replacing components that are OK or employing so called expert services . Hope this helps anyone with same symptoms .
With luck we live and learn
Sc will not start
» Maddie Cops To Start Digging Up Resort - Daily Mirror
» Would like to start a forum from scratch.
» NEW INTEL ::::: PETER DRISCOLL......HAS ANSWERED MY QUESTION .....WHY HAS PERMISSION NOT BEEN GRANTED BY YOU TO SISIP TO START CALCULATIONS , WHAT IS THE DELAY ?
» WikiLeaks: Julian Assange could start publishing leaked details of Swiss bank tax accounts in two weeks
