 1KZ-TE Timing belt
Number of posts : 142
PostSubject: 1KZ-TE Timing belt   Wed Feb 01, 2017 8:46 pm
Hi does timing belt need doing at 100.000 miles and what is the procedure will be replacing all v belts tentioners and idlers at same time and thermostat, any one know the part number for the timing belt please.
Number of posts : 640
PostSubject: Re: 1KZ-TE Timing belt   Thu Feb 02, 2017 1:34 pm
That's 100,000 km per belt.
You're in the UK, just take your chassis and engine number to Toyota, it's a Hilux engine so they have the belt, tensioner and water pump in stock.
IMO I'd buy Toyota for that bit, any 'economy' will be false.
View user profile Online
PostSubject: Re: 1KZ-TE Timing belt   Thu Feb 02, 2017 5:20 pm
Thanks GPW
Invaluable information will be sure I get a Toyota timing belt asap and coolant
PostSubject: Re: 1KZ-TE Timing belt   Thu Feb 02, 2017 6:58 pm
johntidmarsh wrote:
Thanks GPW
No worries.
BTW I created that plate from the Japanese one i found in my van, check yours under the carpet near the door when you hinge the passenger seat bonnet up.
Also check on youtube for the 1KZ-TE cambelt change as the Hilux uses it - so there are some useful videos there.
As you'll be taking off the viscous fan you may also want to re-oil that too - again youtube should supply the howto, but I think they are fairly easy to refurbish.
ETA
Change the thermostat at the same time.
Belt
http://www.dieseltoyz.com/timing%20belt%20how%20to.html
Fan
http://www.nichols.nu/tip482.htm
1KZ-TE Timing belt
