 milky water in radiator. head been fixed all ready.
aaronp
Number of posts : 13
Home City : Hastings
Registration date : 2017-03-02
PostSubject: milky water in radiator. head been fixed all ready.    Thu Mar 02, 2017 11:06 pm
Could it be oil cooler gasket ? I'm not sure. Engine oil fine . Doesn't overheat. Please help
Number of posts : 648
PostSubject: Re: milky water in radiator. head been fixed all ready.    Tue Mar 07, 2017 9:17 am
Sounds strange. I would flush the system properly and see if it comes back.
aaronp
PostSubject: Re: milky water in radiator. head been fixed all ready.    Wed Mar 08, 2017 12:33 am
Took it to a mechanic who diagnosed trans fluid entering coolant through radiator. New radiator and all sweet as now .
PostSubject: Re: milky water in radiator. head been fixed all ready.    Wed Mar 08, 2017 7:25 am
Ah good to know. I was thinking what could cause the milky color.
Number of posts : 644
PostSubject: Re: milky water in radiator. head been fixed all ready.    Wed Mar 08, 2017 8:28 am
Good mechanic, I'd use that one again!
BTW: This is what happened to all the Mercedes when GM took over - they cheaped out on the radiator and the same failure occurred: Transmission oil and water mixed.
In the Mercedes this used to write off 7,000 gearboxes because the coolant would literally eat the bearings in the auto transmission, so I'd be doing a regular change of transmission fluid to ensure you are completely clear of coolant there. This is the one case where I'd risk a complete fluid flush of the transmission. Perhaps the mechanic can test for contaminated transmission fluid?
https://duckduckgo.com/?q=Mercedes+gearbox+failure+coolant+radiator
aaronp
PostSubject: Re: milky water in radiator. head been fixed all ready.    Thu Mar 09, 2017 1:32 am
He did test it and was all clear. Was under pressure one way and not the other so was forcing oil into radiator but no water into trans.
