 Anyone breaking a Hiace with 2lte 2.4 td engine ?
Number of posts : 186
PostSubject: Anyone breaking a Hiace with 2lte 2.4 td engine ?   Fri Mar 10, 2017 11:49 am
I need a sump as mine is porous around the top part of the sump extension part, daft design that allows moisture to sit on top of that part corroding it
Anything about in the UK?
Number of posts : 211
PostSubject: Re: Anyone breaking a Hiace with 2lte 2.4 td engine ?   Fri Mar 10, 2017 12:01 pm
This the one?
http://www.ebay.co.uk/itm/Toyota-Hilux-Surf-LN130-2-4-2L-TE-Engine-Oil-Sump-Pan-1989-1995-445-/192124274348?hash=item2cbb7fc6ac:g:fBsAAOSwdGFYwDCB
PostSubject: Re: Anyone breaking a Hiace with 2lte 2.4 td engine ?   Fri Mar 10, 2017 3:25 pm
TwentyOneThirtyFive wrote:
This the one?
by crikey that's the one cheers bounce I've been searching Hiace and/or 2LTE, just shows I need to open my search listings
Thanks buddy
Number of posts : 583
PostSubject: Re: Anyone breaking a Hiace with 2lte 2.4 td engine ?   Sun Mar 12, 2017 10:38 pm
I know some of the engines are fitted with a front sump, others with a rear sump. The engine is not in the same position in the Hilux, so it may have a different sump. Would be best to check part numbers.
PostSubject: Re: Anyone breaking a Hiace with 2lte 2.4 td engine ?   Mon Mar 13, 2017 7:14 am
darn it, the surf does appear to have a different part number scratch
Number of posts : 539
PostSubject: Re: Anyone breaking a Hiace with 2lte 2.4 td engine ?   Mon Mar 13, 2017 7:39 am
Can your sump be welded?
If it's steel you could clean it up and have it patched , some places can also patch alloys.
View user profile Online
PostSubject: Re: Anyone breaking a Hiace with 2lte 2.4 td engine ?   Mon Mar 13, 2017 8:52 am
While checking the part numbers, it is very weird. The part number for a sump from a japanese van like yours with 2L-TE is also listed for many 2L engines. But not equal to my 2L.
However, when I check my sump part number, it is also listed for 2L-TE engines in Landcruisers.
I think that is the same story again, modifications for 2WD version or 4WD version (with the axle being in the way)
I think you are checking for part number 12101 54182 right?
Here you can buy 12101 54183 (one off) for 185 Euro, new product. It probably fits, but I can't be sure.
http://www.euro-autoparts.nl/artikel_info.php?artikelnr=8193472&kiesmerk=TOYOTA&kiesmodel=5344&kiesgroep=&zoekwoord=&sorteren=produktgroep,%20omschrijving,%20cadeon_nr&weergave=thumb
This brand should also have a local UK reseller.
PostSubject: Re: Anyone breaking a Hiace with 2lte 2.4 td engine ?   Mon Mar 13, 2017 9:11 am
Sorry, didn't realise they would be different.
Using the part number that Hiace4wd has posted above, a bit more pricey but Genuine Toyota - http://www.allcarpartsfast.co.uk/toyota/toyota-1210154182-12101-54184/
Although I'd give them a ring and check, as there is no description for that part.
PostSubject: Re: Anyone breaking a Hiace with 2lte 2.4 td engine ?   Mon Mar 13, 2017 9:31 am
Haha if the 12101 54182 and 12101 54184 are the same fit, I guess 12101 54183 would do as well?
PostSubject: Re: Anyone breaking a Hiace with 2lte 2.4 td engine ?   Mon Mar 13, 2017 9:40 am
Well spotted, I didn't notice it returned 184 when I searched for 182, although it lists both numbers ... I'm now confused.
PostSubject: Re: Anyone breaking a Hiace with 2lte 2.4 td engine ?   Mon Mar 13, 2017 9:49 am
yes i'm going on mine being 12101-54182 which superceeds to 12101-54183 , the hilux is 12101-54310
the sump is porous but only slightly, since getting the rear main replaced my oil spotting has gone from a 5 inch diameter to a smidge of a drop, still annoying me as I hate oil leaks. I'v got some of that chemical metal in a tube that you roll together in your fingers then apply but with the sump fitted access is nigh on impossible, even when the van was over the pit having the rear main the garage let me have a look and you have to get up between the chassis and block
» Breaking News: 4-Year-Old Boy Stabbed To Death At SE London Family Home
» Breaking Bad
» Breaking German Codes Real Reason for 1942 Dieppe Raid
» SKY/Breaking news
» Breaking The Bank ~~Doc~~
Toyota Hiace Super Custom Owners Forum  :: Anything for sale or needed. (for the super custom blah blah) :: I need ...-
