 Pinion seal
frontslide
Number of posts : 17
Home City : Derbyshire
Registration date : 2012-07-27
PostSubject: Pinion seal   Mon Mar 27, 2017 6:25 pm
Can the pinion seal be changed easily or is it an axle shop job? (1994 2.8 3L)
Number of posts : 537
PostSubject: Re: Pinion seal   Mon Mar 27, 2017 8:07 pm
Under the passenger seat next to the engine there should be a plate with the engine, transmission and diff models on it.
I suspect yours is the same as the 4runner as lots of bits seem to be the same:
https://www.youtube.com/watch?v=fW6Yld-8KsY
Number of posts : 582
PostSubject: Re: Pinion seal   Mon Mar 27, 2017 8:24 pm
Yeah you can check out the youtube video, it is the same axle. Even if it wasn't, the idea would still be the same.
frontslide
PostSubject: Re: Pinion seal   Tue Mar 28, 2017 8:51 pm
Need to find out the pre-load torque setting dont want to be guessing.
PostSubject: Re: Pinion seal   Tue Mar 28, 2017 9:39 pm
If the diff is currently free and not whining (i.e. adjusted properly) would it be possible to just do the nut up to the same position as it was to start with?
Also if there is a crush sleeve your options may be limited.
Pinion seal
» Defense Files New Motion to Seal Jail Records
» Deck Profile: The Seal of Orichalcos
