 AC Faulty
Number of posts : 98
PostSubject: AC Faulty    Wed May 03, 2017 1:06 pm
Ac not working switch on dash lights up clutch on ac pump engages pressure in system ok with fan on and set to cold no cooler in front, rear unit switched on but no output from fan . Fuses seam ok suspect a relay maybe any ideas would be welcome.Crying or Very sad
PostSubject: Re: AC Faulty    Wed May 03, 2017 1:38 pm
check the switches in the back? also check in the back side where the cigerette lighter is there are switches there
cheers .Dave
PostSubject: Re: AC Faulty    Wed May 03, 2017 2:57 pm
All switches /sliders in cold position fan in front on full fan in back/overhead only on slow but does go off and on when switch operated. Site glass under front of SC next to windscreen bottle shows fluid moment so assume pump is working but still no cold air and no condensate from drain pipes, my Landcruiser drains condensate continually when AC on, still baffled any more ideas anyone before i commit to local AC centre.
Number of posts : 582
PostSubject: Re: AC Faulty    Wed May 03, 2017 3:21 pm
You also don't feel the pipes getting cold I guess?
It sounds as if you need to go to the AC company.
PostSubject: Re: AC Faulty    Wed May 03, 2017 4:44 pm
That is correct no cold pipes anywhere most unusual especially as the pressure is up and pump turning as there are two systems connected (front and back) there must be a valve or something involved still baffled?.
Number of posts : 537
PostSubject: Re: AC Faulty    Wed May 03, 2017 11:10 pm
There may be a sight glass under the van - in front of the left hand side wheel toward the center.
Clean it and then see what's in there, nothing, fluid or bubbles.
PostSubject: Re: AC Faulty    Thu May 04, 2017 9:54 am
Hi GPW the sight glass underneath is showing plenty movement fluid bubbles I assume this shows pump is working, am about to check the fusses again and relays if I find it.
PostSubject: Re: AC Faulty    Thu May 04, 2017 6:43 pm
Weird, not sure what to suggest.
PostSubject: Re: AC Faulty    Thu May 04, 2017 6:56 pm
Hi Again GPW further to AC problem just got the SC re gassed at local AC place very helpful friend the cabin AC is now very cold but the rear ac fan still refuses to blow found a relay below dash centre marked RRAC this does not click when rear AC activated (tested relay as working) tried all buttons sliders in various positions no joy, can hear a very low fan noise from AC when switch is used could be fan is dicky any help would be appreciated thanks to all.
PostSubject: Re: AC Faulty    Fri May 05, 2017 6:38 pm
Interesting that regassing was useful - perhaps those bubbles were lack of gas.
The rear A/C is in the roof above the front seat headrests - is that the one failing? There are 2 fans under there BTW.
PostSubject: Re: AC Faulty    Fri May 05, 2017 7:16 pm
Hi yes the unit above the headrests switch on the front vents pointing rearwards two slider controls in the middle a very faint fan noise when switch on used to be a powerful blower last summer, the SC is low mileage so assume its not had excessive use. Think it must be some control fuse relay thermostat etc circuit diagram would be useful if anybody has one.
Living in hope JT69
PostSubject: Re: AC Faulty    Sun May 07, 2017 12:38 pm
Hi All Air Con now fully functional blowing cold front and rear, problem was fuse in box next to footrest marked AC 2 had been removed and put back in wrong place, just one of life's mistakes.
Great Joy JT69
PostSubject: Re: AC Faulty    Sun May 07, 2017 12:50 pm
Brilliant!!
Very rare for a wiring diagram of the super custom, so that was a good find!
Number of posts : 107
PostSubject: Re: AC Faulty    Thu May 11, 2017 12:28 pm
Good job working it out JT69.
I love the A/c in my van. Every baking hot day that I use it I thank God again that I didn't follow the crowd (or is it sheep?_ and buy a tatty VW without A/C for the same money as my Hiace.
Robbos
Home City : Newcastle
Registration date : 2017-08-14
PostSubject: Re: AC Faulty    Mon Aug 14, 2017 9:20 pm
Aircon not working in rear of van. Can anyone recommend a mechanic in sydney or Newcastle
Number of posts : 84
PostSubject: Re: AC Faulty    Mon Aug 14, 2017 11:53 pm
Not familiar with your area but I've had good service with my local Natrad in Brisbane. I guess there will be one down your way.
AC Faulty
» Help index_body vs header faulty
» Forum faulty, appear strange
