 PS fluid change
Number of posts : 215
PostSubject: PS fluid change   Tue May 09, 2017 8:00 am
Last couple of trips out the steering has been a bit jerky when it's first started from cold.  Thinking the PS fluid probably needs changing.
What's the best way to do it on the HiAce?  Just suck it out of the reservoir and refill, turn wheels a few times (and repeat a few times), or is there a drain somewhere?
Number of posts : 652
PostSubject: Re: PS fluid change   Tue May 09, 2017 9:32 am
I don't know Very Happy
But what solved the jerky steering for me was to have the belt tightened. I had the same symptoms, just after starting.
PostSubject: Re: PS fluid change   Tue May 09, 2017 9:44 am
Belt seems okay, I retensioned it about 1000 miles after fitting. What a pain of job that is! But I'll double check, just to be sure.
Number of posts : 688
PostSubject: Re: PS fluid change   Tue May 09, 2017 4:19 pm
The reservoir has a thin gauze filter across it so you cannot stick a tube into it without damaging it,
I've looked at the pipework underneath and decided that the best idea was to remove the actual reservoir which has a pipe clamp underneath (feed) and to the side (return), empty and clean it and then refill.
Then run the van for a while and do it again just to get a bit more new fluid in there.
View user profile Online
PostSubject: Re: PS fluid change   Tue May 09, 2017 7:54 pm
Thanks GPW, that's a pain. Will have a poke about in more detail at the weekend then.
PostSubject: Re: PS fluid change   Sat Jun 03, 2017 2:48 pm
My PS fluid reservoir did not have any mesh, so I was able to empty it with a syringe. Gave it a few flushes but then ran out of fluid, so hopefully have done enough Smile
PostSubject: Re: PS fluid change   Sat Jun 03, 2017 8:24 pm
That's handy!
May want to get a new one at some stage, the filter is quite interesting:
The fluid is sucked out of the bottom and pumped back into the top, so the filter is constantly working to deposit any bits on top of the gauze, and when the gauze gets blocked it overflow and tells you in that way that the filter is blocked.
Ace MM
Number of posts : 49
Home City : California USA
PostSubject: Re: PS fluid change   Mon Sep 18, 2017 10:44 pm
Same change I made. I'll look into a replacement mesh.
Number of posts : 152
PostSubject: Re: PS fluid change   Tue Sep 19, 2017 8:42 am
Easy to change fluid disconnect return pipe put end in container, put new fluid in tonic bottle invert with end in reservoir run engine till clean fluid appears in container, stop engine, top up to correct level reconnect return pipe dispose of old fuid ethicly job done.
PostSubject: Re: PS fluid change   Tue Sep 19, 2017 7:46 pm
That's a good idea! Thanks!
PS fluid change
» How to change header text
» How to change forum name?
» How do i change ranks?
» change chatbox name
» Change the logo of Brown & Brown theme?
