 Front shock bushes or is it time to get new shocks as well?
Number of posts : 138
PostSubject: Front shock bushes or is it time to get new shocks as well?   Fri Aug 18, 2017 1:34 pm
Hi All,
I had an advisory about my front shock bushes on the last MOT. I was thinking as these are probably the same shocks that came out of the factory that maybe I should replace those at the same time. Looking at Toydiy the shocks look to be part number 48511-29595, and the cushions (which I think may be bushes) are 90948-01003.
Now where do I order these from? Ebay is so not helpful when you have the 4wd 2.8D Hiace.
Answers on a postcard to this address.
Rich
Number of posts : 652
PostSubject: Re: Front shock bushes or is it time to get new shocks as well?   Fri Aug 18, 2017 2:35 pm
Just throw in the part number (without anything else) into Ebay, search in Europe.
There are two offers from Germany, one being Bilstein shocks.
Number of posts : 215
PostSubject: Re: Front shock bushes or is it time to get new shocks as well?   Fri Aug 18, 2017 2:53 pm
Genuine Toyota:
http://www.allcarpartsfast.co.uk/toyota/toyota-9094801003-retainercush/
Seems to offer a different part number for the shock, so has probably be superceded, but best to call them to find out.
http://www.allcarpartsfast.co.uk/toyota/toyota-4851129595-48511-29596/
I've used this company for a few parts and they've always been spot on.  Couple of times when parts have had to come from Japan they have let me know of the delay.
hth
Number of posts : 221
PostSubject: Re: Front shock bushes or is it time to get new shocks as well?   Fri Aug 18, 2017 4:00 pm
I'm planning on replacing my shocks all round when I finally find some lowered rear coils, I've looked into sizes and eyelets and I think VW T4 fronts will fit the front of the Hiace, I've trial fitted and length is spot on, I will have to push out the lower bush and trim the eyelet down to fit in the hub shock mount. Advantage is the T4 have a bigger range of gas and uprated shocks than the Hiace has
PostSubject: Re: Front shock bushes or is it time to get new shocks as well?   Fri Aug 18, 2017 4:07 pm
What do you mean with a bigger range? As in more products to choose from? You only need 2 right? Razz
Bilsteins are already good and reasonably priced on Ebay.
I don't know if it fits, and I don't really see the point, but don't try something like that for the rear because the axle weight is entirely different in the rear. (front is actually very comparable with the T4)
PostSubject: Re: Front shock bushes or is it time to get new shocks as well?   Fri Aug 18, 2017 8:14 pm
Have you got a link to them bilsteins as I can only find budget shocks, when I said bigger range I meant more suppliers of the same type of shock, we seem very limited in the hiace world for aftermarket custom parts lol
PostSubject: Re: Front shock bushes or is it time to get new shocks as well?   Mon Aug 21, 2017 9:13 am
Here: http://www.ebay.nl/itm/2x-Stosdampfer-Dampfer-Fahrwerk-BILSTEIN-B4-OE-Replacement-19-227948-Vorne-/263023193931?hash=item3d3d676f4b:g:ay0AAOSw3gJZNtvj
PostSubject: Re: Front shock bushes or is it time to get new shocks as well?   Mon Aug 21, 2017 1:13 pm
Thank you Hiace4wd and TwentyOneThirtyFive. Will be ordering a set of these at the end of the month. Are they easy to fit, or do I need a special tool to depress the shock for fitting?
Number of posts : 689
PostSubject: Re: Front shock bushes or is it time to get new shocks as well?   Tue Aug 22, 2017 1:14 pm
I think you'll just need access to each end, if they are a bit springy I doubt they'd be hard to push in by hand.
» Diane Schuler Was Drunk and High at the Time of the Crash That Killed 8
» Seeking one time donations or ongoing relationship for my twins!
» Daily Express front page
Toyota Hiace Super Custom Owners Forum  :: Anything for sale or needed. (for the super custom blah blah) :: I need ...-
