 wafoo
wafoo
Number of posts : 19
Home City : london, N22
Model and year : Lexus 1994 7 seats 3L Class MPV
Registration date : 2011-12-27
PostSubject: wafoo   Sat Aug 26, 2017 11:32 am
KZH 1994 engine suddenly stips, runs okay for a while and stops.. Squiggly wire coil symbol on dash. Thinks it's the EDC/
any ideas. (new fuel filter fitted and hose clips)
wafoo
PostSubject: Re: wafoo   Sat Aug 26, 2017 11:42 am
Hint for cooling system on 1994 KZH and the like. Check under body , by the driver side rear wheel for corrosion on the elbow pipes for rear heating Mine were leaking and badly corroded. 15mm copper will fit into the rubber pipes. (Plumbing)
Number of posts : 563
PostSubject: Re: wafoo   Mon Aug 28, 2017 10:06 am
I guess check the ECU. Perhaps you can already see some errors on the print, leaking capacitors or such, when you open the ECU.
It sounds like the other issues that people reported with having a bad ECU.
wafoo
PostSubject: Re: wafoo   Tue Aug 29, 2017 2:54 pm
I.ll have a look at the ECU. Thanks, hope you're right...
wafoo
