 Advice on 2.4 petrol or 2.8 diesel
swookimin
Home City : Melbourne
Registration date : 2017-08-30
PostSubject: Advice on 2.4 petrol or 2.8 diesel   Wed Aug 30, 2017 6:59 am
Hi everyone,
I'm looking at getting a super custom and I have read that some people say to steer clear of the 2.4 engines, as they are known for having over heating and cracked head issues? How common is this? i guess it is fairly common since I have read it from a few different sources. And do they have any other common problems? I'm in Australia so I don't want it overheating on me in summer.
I have seen a couple of 2.4 petrol super customs for sale but I'm thinking maybe I should wait until a 3 litre diesel comes up?
Any advice from owners of either engines would be great!
Thanks!
Number of posts : 564
PostSubject: Re: Advice on 2.4 petrol or 2.8 diesel   Wed Aug 30, 2017 10:30 am
Well, I have the 2.4 diesel (which is the same as the 2.8 diesel, except size). I'm quite annoyed about the noise it makes, even though I already put some sound insulation in it. But this is more an issue for long trips. I wouldn't mind having the petrol because of that. Al though, to be honest, I don't know how much noise the petrol engine makes because we almost don't have it here. And I guess the petrols have more power, unless you are comparing to 2.4 turbodiesel and 3.0 turbodiesel.
The 2.4 and 2.8 diesels can overheat, but I'm not sure why. Perhaps just poor maintenance?
I can go up the mountain on a highway, full throttle with our loaded campervan, in 40 degrees Celcius, and it does not overheat at all (even though new cars and even trucks sometimes had issues with the heat).
However, I suppose it can go downhill pretty quickly when some components start failing. When you buy the diesel I think it would be best to flush the coolant system a couple of times. Possibly changing thermostat and the cap. And check if you can sometimes hear the Visco fan come on under load (driving up climbing highway or so)
Number of posts : 84
PostSubject: Re: Advice on 2.4 petrol or 2.8 diesel   Thu Aug 31, 2017 12:33 am
My only experience is with the 2.8 diesel (non turbo). I did have an issue with overheating but this was cured by replacing the radiator. Put that down to poor maintenance in it's past life in Japan. Possibly mixing red and green coolants. Since the replacement there has never been a problem in summer including long trips from Qld to central Vic.
It will sit all day at 110km/h on the flat (where legal) but will loose speed rapidly on any sort of a climb. I mentioned to my Toyota serviceman that I perhaps should have gone for a 3litre turbo but he said they haven't proved as reliable as the 2.8. Apparently they aren't the same engine as that in the Prado (my other vehicle).
Fuel consumption on the diesel averages around 11l/100km but varies a lot with conditions. My fuel tank is only 65 litres and I've had the range vary from 450km to almost 600km. The low end is a bit uncomfortable on long runs. Petrol engines usually have higher fuel consumption so that my be something to watch, if they have the same fuel tank size.
» Some petrol stations have number regnication system cameras
» Advice Columns
» Ab sculpting advice from a guy that does't have visible abs
» On Religious Knockers...Karen's Advice Worked!
» Witness Statement Karen McCalman
