 Fuse boxes
jen's car
Home City : Melbourne
Model and year : 1993 Super Custom 1KZH turbo diesel auto Japanese import to Oz. The escape machine, just getting started with it, few things I don't understand or can't do myself.
Registration date : 2017-09-17
PostSubject: Fuse boxes   Sun Sep 17, 2017 10:38 pm
Still on the topic of fuse boxes - last post i can find is 8 years ago - i've got one i think under the steering wheel close to the middle of the car but how on earth do you open it? It's a long black thing marked A. I can find no way to open it - hoping moon roof is not closing due to that rather than tearing roof apart.
Number of posts : 688
PostSubject: Re: Fuse boxes   Mon Sep 18, 2017 9:26 am
There's a clip on it, you need to get close with your head + a torch.
I've posted a bit on the moonroof as mine was stuck shut.
I have been unable to find a wiring diagram for the roof and the motor is not trivial to access. I suspect the rear rood would use the same fuse though. There's a blue box with relays n stuff in the roof, the front roof lining needs to come out but it's tricky if you don't have the rear one out as that one is fitted on top with some decent clips. IIRC some people have extracted it without removing the lining but I could not.
Also if you need to get to the motor it's under that lining.
Check first that it's not just stuck and can be jiggled but don't force it.
TraceyT
Home City : Logan
Model and year : Hiace 1994 Turbo 3ltr Diesel Super Custom
Y-KZH100G-MRPGT
Registration date : 2009-05-30
PostSubject: Re: Fuse boxes   Sat Oct 21, 2017 12:55 am
I found mine on the front passenger side. Just pop open the panel and there it is. Changed the pink fuse and got it going again.
Fuse boxes
» Ammo boxes
» Cajas Raras y flores - Doll house - Eigentijos Origami -Faboluos Origami Boxes
» [MF] Tomoko Fuse - Enjoyable Origami to decorate your Living
» 3 WW2 Canadian Red Cross POW Boxes
» Application form with text boxes
