 Disabling a door sensor
Chesco
Number of posts : 7
Home City : Saint Malo
Registration date : 2017-09-13
PostSubject: Disabling a door sensor   Thu Sep 21, 2017 4:53 am
Hi everyone,
I'm having a problem on my Super Custom regarding the passenger door sensor.
The passenger is very slightly bent at the spot that is normally pressing the door sensor and turning off the "open door" red light on the dashboard.
Therefore, the light never turns off on the dash board (it also lights the spot where you insert the key near the steering wheel) and it slowly drains the battery.
Here is the sensor:
One of the previous owner managed to disable the sensor on the driver side, it looked like the plastic part that moves in the sensor has been pulled off.
I hesitate pulling it off as the electrical circuit might stay open and light would never turn off...
Anyone experienced the same issue and found a solution?
Thanks in advance for your help!
Number of posts : 537
PostSubject: Re: Disabling a door sensor   Thu Sep 21, 2017 10:01 pm
They are a very simple switch, an open door means the spring pulls the wire down to earth.
To disable it just pull the connector off and insulate it.
A better idea would be to buy a new one, or add a bit to the end of the plastic - like a small self tapping screw. The good news is that all cars basically use the same switch so one will fit!
e.g:
http://www.ebay.co.uk/itm/Volvo-S40-95-04-Open-Close-Door-Warning-Ajar-Indicator-Switch-Sensor-/252852734084?hash=item3adf328884:g:93kAAOSwpkFY6lfV
Probably a Toyota switch will do it.
PostSubject: Re: Disabling a door sensor   Sat Sep 23, 2017 6:45 am
I had that problem solved it by putting a small washer behind it.
Chesco
Number of posts : 7
PostSubject: Re: Disabling a door sensor   Sun Sep 24, 2017 2:15 am
Thank you for your replies.
Actually I don't need to replace it as the sensor is working well, it is the door that is bent and doesn't push properly the plastic tip!
I put a folded tissue in the meantime but it doesn't look good...
My question is just: if I pull off the plastic tip, will the light stay on or off?
Otherwise I'll try to stuck it..
PostSubject: Re: Disabling a door sensor   Sun Sep 24, 2017 10:48 am
Here's another way to make the plunger longer:
http://www.ebay.co.uk/itm/10x-Rubber-bleed-screw-caps-brake-bleed-nipple-caps-grease-nipple-covers-NC1Bx10-/331942454724?hash=item4d494fe5c4:g:1LQAAOSwOMdZSXrp
I use a similar trick with my E30 boot switch to stop flat batteries!!
Chesco
Number of posts : 7
PostSubject: Re: Disabling a door sensor   Sun Sep 24, 2017 10:51 am
Nice one! Thanks for the idea, I'll try to find something similar.
Ace MM
Number of posts : 41
Home City : California USA
PostSubject: Re: Disabling a door sensor   Sat Sep 30, 2017 4:43 am
I use "rubber bumpers" on the door. Adhesive backed rubber.
The switch is available and I'll eventually replace it.
» death to a paedophile
» No post count/Disabling post count on a particular forum
» Disabling text selection/highlighting
» Disabling the mobile version
