 Electric steering wheel adjustment stopped working
Will09
Number of posts : 4
Registration date : 2017-09-24
PostSubject: Electric steering wheel adjustment stopped working   Mon Sep 25, 2017 12:01 am
Hi all,
Having the issue described above with the electric adjustable steering wheel. Unable to work out which fuse to check (although all in the drivers side fuse box seem ok). My thoughts were maybe it is a jammed cog in the adjuster? It does not make any noise though, so may be a connection issue or fuse somewhere.
Any help would be greatly appreciated!
Number of posts : 606
PostSubject: Re: Electric steering wheel adjustment stopped working   Tue Sep 26, 2017 2:56 pm
I appear to have a mechanical one so maybe not much help.
However I'd try putting an accurate voltmeter across the battery, wait until everything settles down (glowplugs off!) and then see if there is a voltage drop when you try to move it.
If there is it's jammed, if not it's a fuse or switch likely (open circuit).
» Mobile version not working on my site
» Image Resizing Has Stopped Working
» #1386 Widget Latest topics stopped working.
» pfdtool.exe has stopped working Error
» James Connolly: A Working Class Hero
