 Suspention knock
Number of posts : 125
PostSubject: Suspention knock   Sun Oct 01, 2017 8:26 pm
Anoying knock on front suspention on uneven road surface especialy when goeing over speed bumps anyone got the same problem and or solutions please.
Number of posts : 89
PostSubject: Re: Suspention knock   Mon Oct 02, 2017 3:14 am
I had that a while back, found to be a broken bracket holding the (I think) anti-sway bar. A replacement bracket couldn't be found but a local steel working place was able to make a copy as it's only mild steel.
I guess there are plenty of other things that could cause it though.
Number of posts : 625
PostSubject: Re: Suspention knock   Mon Oct 02, 2017 10:24 am
Yeah always check the stabilizer bar (anti-roll anti sway bar) first. Check the links, the connections, and the big rubbers holding the bar.
PostSubject: Re: Suspention knock   Tue Oct 03, 2017 12:15 pm
Checked all bushes and brackets on suspention ball joints etc but no movement on any shocks and bushes are new the knock just sounds like tortion bars lifting of pivot points and droping back on they are not captive at the adjustment end could they possibly need adjusting????.
Number of posts : 600
PostSubject: Re: Suspention knock   Tue Oct 03, 2017 2:10 pm
The torsion bars will be pressing with great force on all bearing surfaces all the time - they can't rattle unless you completely unload them.
Can be difficult to track down these things - could even be a loose brake backplate.
I did have a difficult to track rear track rod rattle on my car a few years ago - it only showed itself when I pulled the road wheel about on a particular axis - like 10 to 5 on a clock, 3:15 and 12:30 for instance were silent.
Also check the shocks are bolted in nice and tight and any rod ends are not loose - had a loose front tiebar on a Honda, sounded like it was falling to bits on cobbles but it just needed tightening down a bit.
Suspention knock
