 kzh138 manual
Oceanic4005
Number of posts : 7
Home City : Squamish, BC
Registration date : 2017-05-22
PostSubject: kzh138 manual   Sun Oct 15, 2017 7:45 am
hello, does any one have info or manual on this mode please.
is this the same as the rzh?
thank you
Number of posts : 648
PostSubject: Re: kzh138 manual   Sun Oct 15, 2017 9:22 pm
I don't have a manual for you but some generic info. It is not the same as the RZH (or LH) as the RZH came with the 2RZ engine, a 2.4 petrol. The KZH is with the 3 liter turbodiesel engine, the 1KZ-TE.
See here some basic info from toyodiy.com
GRADE: DX: DX TYPE (05/1992+ GRAND CABIN D TYPE)
DESTINATION: JPN: JAPAN
ROOF: HRF: HIGH-ROOF
ENGINE: 1KZTE: 3000CC DIESEL TURBO
FUEL SYSTEM: TDE: TURBO DIESEL WITH EFI
GEAR SHIFT TYPE: 4FC: ATM, 4-SPEED FLOOR SHIFT
DRIVE TRAIN: 4WD: 4-WHEEL DRIVE FLOOR:
V1: STANDARD VAN LOADING CAPACITY: 1000K: 1000 KILOGRAMS (08/1996+ 1250 KILOGRAMS)
NO.OF DOORS: 4D: 4-DOOR
SEATING CAPACITY: 03S: 3-SEATER
SIDE WINDOW: SG: SIDE WINDOW GLASS
Oceanic4005
Number of posts : 7
PostSubject: Re: kzh138 manual   Mon Oct 16, 2017 12:40 am
Thank you Hiace4wd. I'm looking at the kzh138 which is the non turbo. I'm not sure if it is the 3L or 5L version. I suspect the 5L.
PostSubject: Re: kzh138 manual   Mon Oct 16, 2017 8:30 am
No, if there is KZ in the number (KZH138) it comes with the 1KZ engine, and this engine is (in the Hiace) always with turbo (1KZ-TE).
If there is the 2L, 3L or 5L engine code in there, then the number is starting with LH1** (instead of RZH1** or KZH1**).
I have the 2L diesel, non turbo, and the model code is LH118.
If you're looking at a KZH model, and you think it doesn't have a turbo: maybe it is because you don't see the turbo as it is under the right hand side seat.
kzh138 manual
Toyota Hiace Super Custom Owners Forum  :: General :: Useful Links-
