 Looking for transmission spec (1991 hiace truck 4x4)
mitchem4
Home City : Seattle
Registration date : 2017-10-24
PostSubject: Looking for transmission spec (1991 hiace truck 4x4)   Tue Oct 24, 2017 2:06 am
Hello all - I am new to the forum. Recently I imported (into US) a 1991 Hiace truck. I am curious about changing the final drive gear ratios but first want to find the gear ratios of each speed within the transmission.
Does anybody have a comprehensive collection of transmission specs, or know where to look? I have done plenty of looking online but cant find them.
Transmission code: R351F
Final Drive: G152
Chassis: U-LH85-MDP
Engine: 2L
Apologies if this is a common question - I wasn't able to find the answer by searching.
Number of posts : 625
PostSubject: Re: Looking for transmission spec (1991 hiace truck 4x4)   Tue Oct 24, 2017 8:08 am
I wrote this kind of stuff (about final gear ratios) down in this topic:
http://hiace-super-custom.free-boards.net/t2911-toyota-hi-ace-axle-information
Please also check out the PDF which gives all possible gear ratios.
If you want to have longer gears, so a lower final gear ratio number, you will be able to find it. If you want a higher number for even shorter gears, it will be hard to find.
As you probably know you should change the final gear ratio in both axles.
Since your from the US, you could find a 4runner wrecker fromt the same era (early nineties) and take a lower final gear ratio (longer gears) from there (by also checking the vin plate). But you would have to double check in the parts system (toyodiy.com) to make sure, before you buy something.
PostSubject: Re: Looking for transmission spec (1991 hiace truck 4x4)   Tue Oct 24, 2017 8:13 am
The gear ratios of the the R351F are not on the wiki page, but I guess the other R transmissions will not be far off with ratios, so you got an idea.
https://en.wikipedia.org/wiki/Toyota_R_transmission#R350
mitchem4
Home City : Seattle
PostSubject: Re: Looking for transmission spec (1991 hiace truck 4x4)   Wed Oct 25, 2017 3:40 pm
Thanks for the info - thats helpful. I would still like to figure out the transmission ratios. After looking at what is listed for the other "r" family transmissions, its probably safe to assume 5th gear is 0.8xx.
PostSubject: Re: Looking for transmission spec (1991 hiace truck 4x4)   Thu Oct 26, 2017 12:25 pm
What is your goal? Do you think it revs too much (too noisey) in fifth gear?
As said, you can choose longer gears, but you may end up with an underpowered vehicle. Of course, diesels have a lot of torque in the low rpm, but still on the highway you shouldn't be too low in rpm.
mitchem4
Home City : Seattle
PostSubject: Re: Looking for transmission spec (1991 hiace truck 4x4)   Fri Oct 27, 2017 6:23 am
Yes - Id like to reduce the engine rpm at highway cruising speeds. My current final drive ratio is 5.125, which seems excessively torque-y.
You are right, I will need to be careful not to make too drastic of a change. 4.56 final drive parts are readily available and seem like they could be suitable. I should look to see what other ratios were used by hiaces (with 2.4L engines).
PostSubject: Re: Looking for transmission spec (1991 hiace truck 4x4)   Fri Oct 27, 2017 8:06 am
We put some sound isolation in the front cabin, and where the metal goes down into the floor, so also where the round plate above the gearbox is. This really helps. It won't become super silent or anything, but it makes a long journey much more tolerable. We used a mat that is heavy and out of one piece (which you cut into shape) so there are no openings.
The 5.125 final gear ratio is really nice for off-roading. I think most Hiaces have 4.875 which is also quite close.
» Baby Hope, Found Deceased 7/23/1991, New York
» Man caught driving with dead body
» Royal Scammer Rasheed Mustapha Arrested in Nigeria After Three Years on the Run
» Antonia Bilić, Croatia
» Xe r?i xe n?a xe măi
