 Thermostat stuck open?
LiamM
Home City : Vancouver
Registration date : 2017-01-22
PostSubject: Thermostat stuck open?   Wed Nov 08, 2017 3:25 am
Hey folks,
I noticed last winter that my Hiace would never reach the mid engine temp mark in the cold. I'm in Vancouver so it wouldn't go below freezing often but still struggled to make it over 3-4 of the digital bars on the dash engine temp indicator. Wasn't getting much heat out of the vents.
Anyone experienced this? The same condition is starting again this winter. Seems like my thermostat is stuck open or something Question
Number of posts : 210
PostSubject: Re: Thermostat stuck open?   Wed Nov 08, 2017 7:40 am
yep, when I first got my van it was very slow to reach temperature and would often loose engine temperature easily.
Replaced the thermostat and it has warmed quickly and been stable in the middle of the gauge (old style gauge) ever since.
Thermostat looked okay but I never bothered to test it, guess spring was weak and it was opening too easily.
Number of posts : 563
PostSubject: Re: Thermostat stuck open?   Wed Nov 08, 2017 7:50 am
Yeah replace thermostat, and throw the old one away.
Number of posts : 529
PostSubject: Re: Thermostat stuck open?   Sun Nov 12, 2017 12:59 pm
I never understood testing thermostats unless to verify a diagnosis, after all the effort of getting the old one out only a new one is ever going back in for me too Smile
PostSubject: Re: Thermostat stuck open?   Mon Nov 13, 2017 8:49 am
@GPW, in general I agree, but sometimes you cannot reproduce the issue at the time of replacement.
Lets say your back in the UK, wanting to replace the thermostat because somewhere in Spain it was getting hot on a steep mountain. Than it could be useful to see if it was the thermostat.
But typically speaking, you have some kind of issue that is easy to reproduce. Like the topic starter. The van isn't getting warm, replace thermostat and go for a drive to know it is resolved.
PostSubject: Re: Thermostat stuck open?   Mon Nov 13, 2017 9:28 am
Yes I'd test for diagnosis, but I'd never put it back in unless I was stuck without a new one and the old one was not jammed shut Smile
PostSubject: Re: Thermostat stuck open?   Mon Nov 13, 2017 9:32 am
Yes I agree.
By the way, if you are on the road (holiday roadtrip) having problems and you can't get a thermostat, then you can simply run without a thermostat. On a summer holiday, this will be fine.
In colder winter times, you could put some cardboard in front the radiator (partially at first), but you have to be careful as it can overheat quite quickly.
Number of posts : 89
PostSubject: Re: Thermostat stuck open?   Mon Nov 13, 2017 2:10 pm
Have looked at my thermostat houseing a couple of times with a view to changeing it as matter of prevention (its 21 years old and probably original) mine is a 3ltr turbo and its no easy job, it will have to wait till I pluck up courage to dive in.
PostSubject: Re: Thermostat stuck open?   Mon Nov 13, 2017 3:30 pm
I'll probably wait until the timing belt and then change the belt, water pump, coolant and thermostat all at the same time.
BTW don't lets cats near any coolant, it's lethal for them.
» OPEN EUROPE BULLETIN...........what"s going on with the fat cat MEP"s
» Cigarettes banned from open display
» Open letter to Crimewatch
» OPEN LETTER TO THE MCCANNS
» Sofia Leal's Open Letter to Kate McCann
