 Transmission solenoids a340e
Lovethatvan
Home City : Wellington
Registration date : 2017-12-13
PostSubject: Transmission solenoids a340e   Sat Dec 16, 2017 6:03 am
Hi there, I think I need to replace the solenoids, Iím looking at kits from China and want to make sure I get the correct ones. Does anyone have the oem numbers for these? Itís a 2wd... Thereís plenty of a340e parts, not sure if it matters if it doesnít say hiace (plenty say Lexus etc, not sure if the A340e is different for different vehicles??) The symptoms are... 20 mins into driving from cold the o/d flashing light comes on - intermittently - and the gearbox appears to be in limp mode - by that I mean it seems like itís in third gear when Iím setting off from traffic lights... I can manually shift fine. Did a fluid change and the problem came on 40 mins into driving.... Any help is very appreciated
Lovethatvan
PostSubject: Re: Transmission solenoids a340e   Mon Dec 18, 2017 3:36 am
Just to add... my alternator just went kaput (took it out n got it bench tested). I just learnt that dodgy alternators can cause transmission issues (for anyone surfing around that comes across this). So... Iím hoping of course that a rebuilt alternator will make the trans problem go away....
Number of posts : 625
PostSubject: Re: Transmission solenoids a340e   Mon Dec 18, 2017 8:28 am
You can create an account on Toyodiy.com and enter your VIN, then click through the system to find the solenoid you are looking for. Then you can get the part numbers.
Then you can also search on that part number to see if it exists in other models, so you can see if it is the same as in a Lexus.
Number of posts : 602
PostSubject: Re: Transmission solenoids a340e   Mon Dec 18, 2017 7:57 pm
Also try a partial trans fluid change before you decide.
Lovethatvan
PostSubject: Re: Transmission solenoids a340e   Sat Dec 30, 2017 8:43 am
Thankyou for the replies, itís very helpful. Just to provide a conclusion. After doing a second partial fluid change I was surprised to realise itís pink brown milky coloured.... which I think must be a recipe for a trans cooler leak in the radiator... oh dear. So my next step is to figure out if itís possible to put an external cooler on and blank the hoses off.
» NATO Greece suspected transmission of classified information Russia
» Mercedes W5A580 transmission woes for Dave, Iguanaman and others
