Nandun New Member
Number of posts : 13 Home City : Colombo, Sri Lanka Model and year : 1993 Hiace super custom limited Registration date : 2007-04-16
 | Subject: Turbo Pressure Sensor location Sun Dec 24, 2017 4:05 pm | |
| Hi All,
I have a SC with 2LTE and just wanted to know where is the Turbo Pressure Sensor is located in 2LTE, I'm getting a error code that related to turbo pressure sensor and i cannot locate the sensor.
Thanks, Nandun |
Hiace4wd Hiace Master
Number of posts : 627 Home City : Netherlands Model and year : 1994 Toyota Hiace 4x4 DIY camper Registration date : 2016-02-01
 | Subject: Re: Turbo Pressure Sensor location Wed Dec 27, 2017 8:45 am | |
| The parts system show it floating around the left rear of the engine, probably near the throttle body. Not very clear.
If you google for "toyota 89420-26040" you can see what it looks like. It may not be on the engine, but against the backwall or something. |
Nandun New Member
 | Subject: Re: Turbo Pressure Sensor location Wed Dec 27, 2017 10:51 am | |
| - Hiace4wd wrote:
- The parts system show it floating around the left rear of the engine, probably near the throttle body. Not very clear.
Thank you! will have a look, but that day we searched everywhere and coudn't find anything. can you see anything here? https://i62.servimg.com/u/f62/11/21/16/98/s-l16010.jpg |
 | Subject: Re: Turbo Pressure Sensor location Wed Dec 27, 2017 11:30 am | |
| Well, what is the plug connected to on the upper right, on the right of the throttle body? Down right from the three wires? It is supposed to look like this:  So I would check all walls on that side of the engine. |
GPW Hiace Master
Number of posts : 606 Home City : Cambridge, UK Model and year : Model: KD-KZH100G-MRPGT
 | Subject: Re: Turbo Pressure Sensor location Thu Dec 28, 2017 11:56 am | |
| Looks the same as the 1kz one. You should be able to find it by tracing a thin manifold pressure line to it, perhaps going through a small filter first.
If you do find the small filter then replace it (or clean it with brake cleaner and dry it thoroughly) as when blocked up with diesel crud it can block the pipe so the sensor doesn't record anything.... |
 | Subject: Re: Turbo Pressure Sensor location  | |
