 2.4 LT Sump Removal - Anyone Done It ?
Number of posts : 221
PostSubject: 2.4 LT Sump Removal - Anyone Done It ?    Tue Feb 20, 2018 2:49 pm
I'm asking if anyone out there has replaced or removed the sump on their 2.4 LT motor as mine is leaking from porous metal, I've been told that either the engine will need to be puller up of the mounts or the subframe dropped so the sump will squeeze out? neither of which I am looking forward too, so just a shout out there to see if this has been done as is it as bad as I think it will be
Number of posts : 152
PostSubject: Re: 2.4 LT Sump Removal - Anyone Done It ?    Tue Feb 20, 2018 3:56 pm
What neaded is a two post lift makes life easy
PostSubject: Re: 2.4 LT Sump Removal - Anyone Done It ?    Tue Feb 20, 2018 7:18 pm
Not got me one of them only driveway and ramps
Number of posts : 150
Home City : Lincoln England
PostSubject: Re: 2.4 LT Sump Removal - Anyone Done It ?    Thu Mar 01, 2018 3:23 pm
Got the sump off my 1993 year 3L 2779cc Camper by carefully jacking the engine up slightly to allow the sump to clear the cross-member. Seal material had gone & there was oil everywhere MOT Failure!
PostSubject: Re: 2.4 LT Sump Removal - Anyone Done It ?    Thu Mar 01, 2018 7:39 pm
Good news John, did you loosen engine mounts and other stuff or is there enough wiggle room just hacking the engine
PostSubject: Re: 2.4 LT Sump Removal - Anyone Done It ?    Thu Mar 01, 2018 9:30 pm
Had new engine mountings and didn't loosen them.
After getting the sump shield off (12mm AF socket) and taking off the sump bolts (10mm I think- with an extension bar on the ratchet) I carefully hoisted the engine, near point to the gearbox/engine flange until the sump pan slid out to the rear. Porous metal sump? Could be the sealant like mine unless obvious damage/corrosion when you take it off. I think the 2.4ltr is similar to the 2.8ltr sump but am not sure. But you could loosen the engine mountings for added movement. Watch your knuckles!!
PostSubject: Re: 2.4 LT Sump Removal - Anyone Done It ?    Fri Mar 02, 2018 6:58 am
After getting the sump shield off (12mm AF socket) and taking off the sump bolts (10mm I think- with an extension bar on the ratchet) I carefully hoisted the engine, near point to the gearbox/engine flange until the sump pan slid out to the rear. Porous metal sump? Could be the sealant like mine unless obvious damage/corrosion when you take it off. †I think the 2.4ltr is similar to the 2.8ltr sump but am not sure. But you could loosen the engine mountings for added movement. Watch your knuckles!!
cheers buddy, mucho appreciated
» Cipriano Case: Psychic Prosecution Lawyer requests removal of the President Judge Henrique Pav„o
» So, There IS such a thing as "TREE LAWS!" (on Public Parkways!)
» Ad removal?
» Removal of adf.ly
» Forumotion Footer Copyright Links Removal
