 Mechanical issue ??
toyboy
Number of posts : 27
Home City : London
Model and year : Toyota Hiace Custom 4x4
Cruising Cabin 1994
Registration date : 2011-09-26
PostSubject: Mechanical issue ??   Sat Feb 24, 2018 3:31 pm
Hello
Can someone please help? My lovely Campervan (Matilda) has developed a new sound that keeps kinda whirring when i turn the engine off.
The engine stops normally but something else seems to keep going for a minute or maybe longer until finally stopping.
I have a Toyota factory Campervan (November 1994) with a 2779cc 3L engine that i purchased in 2009, she's still in excellent condition and i intend to keep her that way.
Help please.
Toyboy.
Number of posts : 688
PostSubject: Re: Mechanical issue ??   Sat Feb 24, 2018 9:49 pm
Could it just be the engine fan spinning down afterwards? It's a viscous coupling so there is no rigid fixing so it's free to spin down afterwards.
View user profile Online
toyboy
Home City : London
Cruising Cabin 1994
PostSubject: Re: Mechanical issue ??   Sun Feb 25, 2018 12:50 pm
Hi
Thanks for the quick response, I've just checked and the engine fan stops pretty much just after i stop the engine but something else keeps rattling on for a while then slows down and stops.
Thanks for your input though and if you have any other ideas please let me know.
Cheers.
Number of posts : 152
PostSubject: Re: Mechanical issue ??   Sun Feb 25, 2018 4:36 pm
If it has two radiators it could be the electric fan on the horizontal one, if not it can only be the heater fan check both.
toyboy
Home City : London
Cruising Cabin 1994
PostSubject: Re: Mechanical issue ??   Sun Mar 11, 2018 2:30 pm
Hello
Can someone help? I seem to have some sort of guide/runner that keeps going for a while after the engine has been switched off (see Photo) it has only just started to do this and i am slightly worried that it may lead to something else.
The belt seems to drive this thing round and when i turn the engine off the belt slackens so no longer touches it?
It has me baffled.
PostSubject: Re: Mechanical issue ??   Sun Mar 11, 2018 3:54 pm
Ah - interesting!!
That's supposed to guide the belt, if it's running free then the belt doesn't seem quite right to me - the belt should press against it so it should stop with the belt.....
...but here is a diagram that has an idler just touching - so it may be all OK, if the condition + tension of the belt is fine and everything works it's probably nothing to worry about.
See if your engine matches one of the diagrams:
http://jp-carparts.com/toyota/partlist.php?maker=toyota&type=711140&cartype=136&fig=1605
PostSubject: Re: Mechanical issue ??   Sun Mar 11, 2018 4:14 pm
ETA
Key:
AL: Alternator
CC: Cooler Compressor (AC)
CK: Crankshaft
IP: Idler pulley
PS: Power-Steering
TE: Tensioner
VP: Vane pump
WP: Water Pump
Looking at the diagram it seems yours could be the top-right diagram. In there it seems the idler is simply to stop the belt resonating into the close by WP (waterpump) pulley on the longest length, to prevent belt wear as the pulley is travelling the opposite way at that point.
So as long as the AC is working it should be fine, you may just want to spin your idler by hand to check the bearings are good.
toyboy
Home City : London
Cruising Cabin 1994
PostSubject: Re: Mechanical issue ??   Wed Mar 14, 2018 2:53 pm
Hi GPW
And big thanks for that information I really do appreciate your input here.
I took Matilda to my regular mechanic who has serviced her for the last 6 years to check it out and you have confirmed in more detail what he said, the belt is not overly worn in any way and as long as everything is still working then he like you can see no real problem.
Thanks for the diagrams that give a much better understanding of what is happening, they will go in Matildas file and help me get to know my van even better.
Thank you.
toyboy
Mechanical issue ??
» Bill O'Reilly on the black / race issue.
» The Big Issue
» Log In Issue
» Issue about navbar image
» Forum Directory Issue - Forum not appearing on list
