 Power window fuse location
Johnct
Home City : Thornbury
Registration date : 2018-03-11
PostSubject: Power window fuse location    Sun Mar 11, 2018 11:21 am
My 2008 Hiace left hand side (passenger) power window is suddenly stuck half way open. Other window is fine. I thought I should first check the fuse but canít work out which fuse. Iíve found the 4 fuse box locations but none of the abbreviated names seem appropriate. Anyone know how to find the right fuse. Or if I can force the window closed? Or any other suggestions? Thanks
Number of posts : 648
PostSubject: Re: Power window fuse location    Mon Mar 12, 2018 9:40 am
You probably have the power window lock on!
There should be a power window lock button on the driver side door, so passengers (or kids) can't open the windows.
Johnct
PostSubject: Re: Power window fuse location    Mon Mar 12, 2018 10:46 pm
Thanks, it came good eventually after I fiddled with various knobs and settings. I assumed it was something intermittent (my Renault sedan has a similar problem). But you're probably right - after all a Toyota is not a Renault!
Toyota Hiace Super Custom Owners Forum  :: General :: I can see you !!!-
