 Slow windscreen wipers
Andonic
Number of posts : 25
Home City : London
Model and year : Cruising Cabin 1991 pop top selectable 4WD 2.8 Diesel
Registration date : 2018-01-25
PostSubject: Slow windscreen wipers   Mon Mar 19, 2018 6:44 pm
My front windscreen wipers seem really slow to me (even on max speed). Does anyone know if this is something I should worry about or is this normal? Any suggestions?
Number of posts : 138
PostSubject: Re: Slow windscreen wipers   Fri Mar 23, 2018 12:54 pm
Mine run slow as well. It turned out that the middle one had a loose bolt on the spigot(?!) that hold the mechanism to the body of the van. Check these first, that they're not loose against the body.
Unfortunately for me the thread has gone on mine so I've had to use some thread stop glue, which sort of works, but some days they run slower than others.
Hope that helps?
Rich
PostSubject: Re: Slow windscreen wipers   Fri Mar 23, 2018 12:55 pm
*I meant loose nut on the spigot(?!)
Andonic
Home City : London
PostSubject: Re: Slow windscreen wipers   Sun Apr 01, 2018 8:56 am
Hi Rich thanks for this. Any idea how difficult it is to get to all this? Does it involve removing the dashboard?
Number of posts : 689
PostSubject: Re: Slow windscreen wipers   Sun Apr 01, 2018 5:31 pm
In my view there isn't really a dashboard, just bits of trim, an instrument cluster and various switches mounted on a couple of tubular steel tubes that go from side to side.
So I'd suggest taking the biggest most obvious bits of trim of first below the dash and see what you see.
A torch, mirror and local contortionist may help.
View user profile Online
PostSubject: Re: Slow windscreen wipers   Thu Apr 05, 2018 1:20 pm
Not sure how to get to the back of the wipers to be honest. You want to check the wipers where they affix to the bit on the front of the van. There's a little nut that hides under a plastic bit holding the arm onto the mechanism. There's a huge nut holding the mechanism to the front. Check those are all tight enough. If they are fine it can't hurt to squirt some WD40 or silicone lubricant on the nobbly bit that the arm affixes to.
» ...and you think Royal Mail are slow? (this is a lovely story!)
» Every forumotion site is slow
» Slow Loading pages
» fade slow on hover over main buttons phpBB2 forum
» Slow Forum
