 Upgrade rear suspension springs/coil CR5022 airbag part #
jessef
Home City : Vancouver
Model and year : 2000 LWB 4WD SC Highroof camper
Registration date : 2018-02-27
PostSubject: Upgrade rear suspension springs/coil CR5022 airbag part #   Tue Apr 10, 2018 6:42 pm
About to order airbags for the rear springs and would like to confirm the part number.
In this thread : http://hiace-super-custom.free-boards.net/t54-larger-tire-size
They said it's Airbag man CR5022. Can you guys confirm ?
https://www.airbagman.com.au/find/airbag-man-cr5022-for-a-/part-cr5022/cid-0/vid-0/app-1
Number of posts : 688
PostSubject: Re: Upgrade rear suspension springs/coil CR5022 airbag part #   Wed Apr 11, 2018 10:08 am
You'd be best contacting the manufacturers themselves TBH, then if they don't fit you have recourse.
Still missing on the Hiace super-custom (and your camper which may be different) is the actual spec of the Hiace rear springs.
Ideally we need the outer diameter and wire size (mm dia) - easy - but also the free length and the N/mm springiness. There are a few springs around with similar characteristics, I did think the RAV4 springs might fit but since read that the stiffness of the hiace ones may be double at around 108 N/mm according to an obscure australian table I dug up.
It could be that the Mercedes G-class rear springs or variants thereof fit better, I don't know. The point being that if we can identify a vehicle with compatible springs then any airbags, lifts, variants etc that fit that would fit the Hiace.
jessef
PostSubject: Re: Upgrade rear suspension springs/coil CR5022 airbag part #   Thu Apr 12, 2018 10:38 pm
Over in Canada Toyota doesn't support JDM's from Japan.
I see quite a few postings over the years of people fitting airbags and also uprated springs. I'm just asking for confirm the part number CR5022 that I've seen quite a few people use.
PostSubject: Re: Upgrade rear suspension springs/coil CR5022 airbag part #   Fri Apr 13, 2018 11:55 am
I meant the manufacturers of the airbags, not Toyota LOL Smile.
Shame Toyota doesn't support them over there though. I don't know if they fit or not myself, sorry.
» milk to donate in saratoga springs (( up dated found a home ))
» Milk needed near Coral Springs, S. FL
» Fantasy Group RP Part 3 Archived
» Free Windows 10 Upgrade
» Magdalena Weich, 38, Murder Case - Boyfriend, Enrique Macotela, Charged With Felony Murder - Coral Springs, FL
