 Speedo drive behind dash binnacle??
Number of posts : 217
PostSubject: Speedo drive behind dash binnacle??    Mon May 14, 2018 6:06 pm
Had the dash panel off again this weekend as I swapped the subaru double din for a sony out of a celica, whilst out I took the speedo, rev counter binnacle out to remove the bulb out warning as I can't figure out which bulb it is, but now I can't get the speedo drive back on the back of the speedo, to me it's almost impossible as you can't get your hand behind and there's not enough slack in the cable to pull up to the speedo
Anyone done it? How the heck do you do it
Number of posts : 645
PostSubject: Re: Speedo drive behind dash binnacle??    Mon May 14, 2018 9:56 pm
What do you mean by 'speedo drive'?
Mine just have about 4 or 5 electrical plugs into the back of it, the speed is electrical.
Is your's a mechanical drive one? Any pics?
PostSubject: Re: Speedo drive behind dash binnacle??    Mon May 14, 2018 10:18 pm
Well I thought that too, I've had the binnacle out before and not had this issue, maybe just luck, I'll get photo so you can see problem is mot is booked this Saturday so pressure on a bit
PostSubject: Re: Speedo drive behind dash binnacle??    Tue May 15, 2018 10:42 am
It should look like this on the back
Usually I reach in from the open drivers door so my right hand can reach around to the 4 plugs and plug them in.
Before you fit it back you may want to test all the bulbs work, although your deadline may preclude that.
My MOT is on thursday, good luck with yours!!
Remember to take the note about the front suspension (ask them to jack it on the lower wishbones as Toyota recommends: as the torsion bar acts on the top arm so the van always has that pressing down in use.
Number of posts : 133
PostSubject: Re: Speedo drive behind dash binnacle??    Tue May 15, 2018 1:12 pm
Mine goes in for his MOT and service on Thursday too!
Yesterday was some welding around the front drivers side wheel arch. Turns out that 3 years on from the full respray every screw that was holding the plastic trim onto the wheel arch (holds the carpet edge down and hides the chassis number bit) had rusted out. Only realised it when hoovering the foot well and it was sodden.
Today it's having the cambelt done. An expensive week.
PostSubject: Re: Speedo drive behind dash binnacle??    Tue May 15, 2018 1:50 pm
It's a busy MOT day for Hiaces then!
Not many people realise (it appears) that Japanese JDM stuff arrives from Japan
a) Usually without any rust
but
b) Without the usual european rustproofing that Toyota apply for that export market
Then they drive them around like Euro spec vehicles and they rust out. I learned this studying the Mazda Bongo forums before I opted for the Hiace but it's the same for all JDM cars I think,
I even have an official Toyota 'How to rustproof your Toyota Hiace' manual supplement on my PC to tell you how to do it, which if mine ever goes near salt or poor weather will get used - along with a lot of Waxoyl and a sprayer system.
Good luck!!
PostSubject: Re: Speedo drive behind dash binnacle??    Wed May 16, 2018 6:40 pm
PostSubject: Re: Speedo drive behind dash binnacle??    Wed May 16, 2018 7:13 pm
Wow that's completely different!!!!
I can see your problem. It could be that the cable has slipped down a bit and is caught on a protrusion so it needs a bit of jiggling to free it and give you the extra length you need to play with.
Sorry I can't be of more help, good luck.
PostSubject: Re: Speedo drive behind dash binnacle??    Wed May 16, 2018 8:04 pm
I've tried, absolutely no slack anywhere and it disappears through the floor, tried taking air vents out, stereo out just can't get behind it to fit the cable
Mowerman
Number of posts : 10
Home City : Northampton
Registration date : 2018-05-07
PostSubject: Re: Speedo drive behind dash binnacle??    Wed May 16, 2018 8:35 pm
Daft question but would it not just pass the MOT without the speedo working?
There is no need to road test the vehicle these days.
PostSubject: Re: Speedo drive behind dash binnacle??    Wed May 16, 2018 8:56 pm
I know I don't need it for the mot but I do want it work h again so whilst it's apart I gotta get creative or slice my hand in half to get access 😂
PostSubject: Re: Speedo drive behind dash binnacle??    Wed May 16, 2018 9:18 pm
Can you trace the end where it comes out of the gearbox and goes into the floor? It may be hung up under the van, or at least you could confirm the route it follows.
If you've managed to hook it up before it 'must' have come out further before.
If it's a question of tiny hands to access it could you ask a local kid to have a go?
PostSubject: Re: Speedo drive behind dash binnacle??    Fri May 18, 2018 7:38 pm
done it Mad started taking clamps and clips off cable from gearbox end underneath, tried to get some slack still noting, so tried again getting hands behind clocks and low and behold got it connected, van was just testing me.......so put all the clips back on and tried it and yes have a speedo again
PostSubject: Re: Speedo drive behind dash binnacle??    Fri May 18, 2018 8:07 pm
Great news!!!
PostSubject: Re: Speedo drive behind dash binnacle??    Sat May 19, 2018 3:49 pm
How was the mot results mine got a pass only advisory being body has slight corrosion lol
Happy days
PostSubject: Re: Speedo drive behind dash binnacle??    Sat May 19, 2018 9:31 pm
Happy days
Failed on headlamp aim only.
I then found I could just order new ones from Toyota UK, who knew??
So I'll have another go next week with the old candle lamps refitted and the news ones turn up anyway in June regardless...
PostSubject: Re: Speedo drive behind dash binnacle??    Sun May 20, 2018 9:14 am
Not too bad really then GPW
PostSubject: Re: Speedo drive behind dash binnacle??    Sun May 20, 2018 9:16 am
I also had a good look underneath took some pictures of sump oil leak, that is not looking an easy one to fix
PostSubject: Re: Speedo drive behind dash binnacle??    Sun May 20, 2018 9:57 am
This is the problem of not being able to take the sump off because the engine/frame is in the way?
Would a partial engine lift be enough if you could clear the front wheel and run an engine hoist in through the passenger door?
Maybe start a new thread with the photos to see if anyone has a good idea.
» HTML (Google Drive) won't show
» Trump supporters drive over/park on graves at cemetary
» Patrick O'Donoghue
» Driving through - all along I-90 and I-81 (Albany, Syracuse, Watertown, Buffalo.... and anything nearby!)
» Dad delivers baby in car after tunnel dash drama
