 KZH 100 Super Custom transmission
Photoguy
Home City : Westbury
Registration date : 2018-06-28
PostSubject: KZH 100 Super Custom transmission    Thu Jun 28, 2018 11:00 am
I never thought it would be so hard to find out what Auto Transmission filter kit I need for my 96 Super Custom KZH 100G 3.0 diesel. Even ask Toyota Aust. No response?? Can anyone help. ? Thx
Number of posts : 168
PostSubject: Re: KZH 100 Super Custom transmission    Thu Jun 28, 2018 1:12 pm
There is no filter only a fine mesh screen no need to take the pan off and clean it unless you are rebuilding the auto box any bits will come out when you drain the gearbox sump, generally the consensus is just drain sump about 2ltrs put same amount back in. The fluid only needs changing if not cherry red if brown change about three times 100 miles between changes as you cannot drain fluid flywheel just dilute it (holds about 5ltrs ) , if fluid is black and smells very burnt say goodbye to your gearbox before too long unless your extremely lucky. Having taken sump pan of a Landcruiser (same gearbox) I do know what I am talking about, I also did a full fluid change with engine running done by some professionals but a total waste of time and extremely tedious. Good luck
» Custom Rank Title
» Custom Your Domain Name
