 super custom battery problem
horology66
Number of posts : 8
Registration date : 2007-04-23
PostSubject: super custom battery problem   Sun Mar 23, 2008 1:26 pm
Hi, the battery on my super custom keeps discharging. The battery appears to be charging at 13.5v and I can find no voltage leak. I'm wondering if it even has the correct battery fitted. Does anyone know what battery a 2.8 super custom should have?
Tony.
Robbo
Number of posts : 102
Home City : Forster, NSW Australia.
Model and year : 2WD 1996 SC Living Saloon with automatic turbo diesel 3.0lt 1KZ-TE.
Registration date : 2008-02-16
PostSubject: Re: super custom battery problem   Sun Mar 23, 2008 10:06 pm
How long does it take to discharge, and from what starting voltage?
Maybe it is not charging up. The 13.5v will be off the alternator, but does not mean it is actually charging. When you have driven it far enough to normally considered it charged, what voltage is at the battery terminals without it running?
Could have a dead cell.
My 3 litre SC has two batteries. Type of battery will vary in different parts of the world, but needs good capacity to crank a high compression diesel.
horology66
Number of posts : 8
PostSubject: Re: super custom battery problem   Thu Mar 27, 2008 12:25 pm
voltage at terminals not running is 12.8v. I think the battery is too small at 60 Amp/hrs I dont know what the cca is but probably not enough.
PostSubject: Re: super custom battery problem   Thu Mar 27, 2008 12:31 pm
had the same fault.changed the battery but this hasnt cured it.will take a charge but on runs to work(10-15mins max)becomes discharged slowly over a period of about a week or two.when i struggle to start it i know its time for a run lol! .i havent cured it,i just live with it(oh and a spare battery kept at bay).
pushrod
Number of posts : 140
Home City : S Bucks
PostSubject: Re: super custom battery problem   Fri Mar 28, 2008 1:00 pm
I think you need to look at the starting power - should be AT LEAST 500amps. I have a Halfords HCB 072 battery ( which according to H is too small! ) rated at 550amps which seems to work well. It's about 10" across x 7" wide x 8"high. The one in use at the moment is rated at 600+amps and about 1" bigger across & wide. As a general rule of thumb it should cost about 100 Shocked
To upgrade a previous post: I've flattened both batteries down to about 5.5 volts, and it took about a week to charge them up to 6.5/7.0 with my modern charger. I was about to throw them away when I had an idea....... Idea I borrowed my brother's old charger ( ALWAYS charges at 6amps! ) and gave them a good belt of that. After a couple of days they were over 12v, so I put them on modern trickle charge. Now the 'big' battery is in the motor with no problems and the Halfords is at 12.77v 3 weeks after charging. Very Happy Just goes to show that sometimes brutal is best!
Robbo
PostSubject: Re: super custom battery problem   Sat Mar 29, 2008 11:21 am
Probably had sulphated plates and you burnt it off enough to get it going again.
Number of posts : 1118
PostSubject: Re: super custom battery problem   Sat Mar 29, 2008 1:20 pm
didnt they have a song in th 80's ?
pushrod
Home City : S Bucks
PostSubject: Re: super custom battery problem   Sat Mar 29, 2008 3:13 pm
Who, Halfords? I don't remember buying the record.... geek
PostSubject: Re: super custom battery problem   Sat Mar 29, 2008 5:00 pm
no...
The Sulphated Plates. Got to no 34.
pushrod
Home City : S Bucks
PostSubject: Re: super custom battery problem   Mon Mar 31, 2008 1:44 pm
Didn't buy any 'garage' or 'acid' stuff........ Cool
pushrod
Home City : S Bucks
PostSubject: Re: super custom battery problem   Mon Mar 31, 2008 1:47 pm
That's what I thought - but whatever happened it saved me chucking away 200 quid..... Smile
PostSubject: Re: super custom battery problem   Mon Mar 31, 2008 7:00 pm
cheers
shortythadrumma
Home City : MELBOURNE AUSTRALIA
Registration date : 2008-02-08
PostSubject: Re: super custom battery problem   Mon Mar 31, 2008 10:52 pm
yeah ive just experienced the same prob cheers for the info.......
View user profile http://www.myspace.com/shortythadrumma
pushrod
Home City : S Bucks
PostSubject: Re: super custom battery problem   Tue Apr 01, 2008 3:43 pm
What, you don't play any 'acid' or 'garage'? Shocked
shortythadrumma
PostSubject: Re: super custom battery problem   Wed Apr 02, 2008 1:12 am
Well you know every now and then... i mostly like to play BluegrassGhettotechJungleGrunge with a twist of ExperimentalAfroSurfTechnoTripHopTranceGothicGlamBeatBongo in my Van!
PostSubject: Re: super custom battery problem   Wed Apr 02, 2008 10:14 pm
me too..
pushrod
Home City : S Bucks
PostSubject: Re: super custom battery problem   Thu Apr 03, 2008 12:03 pm
I only really like rock n roll ( real stuff ) - sad, innit....... geek
PostSubject: Re: super custom battery problem   Thu Apr 03, 2008 7:18 pm
Not at all. I love loads of music from Evanescence to some Kate Bush, Eva Cassidy to Bob Marley.
Guess its being a d.j. and playing songs for other people ... helps you appreciate a wide range.
shortythadrumma
PostSubject: Re: super custom battery problem   Sat Apr 05, 2008 3:27 am
NICE!!!!! im the same i love it all!!!! anything from reggae to blues to jazz to rock to punk to dance to hip hop...... but i love my funky stuff....... whatever ya do just make it good isay......
Big Lloyd
Number of posts : 103
Home City : East Hertfordshire UK
Model and year : 1994 sc 2.4td
Registration date : 2007-12-07
PostSubject: Re: super custom battery problem   Sun Apr 06, 2008 4:26 pm
Make it 'LOUD' I say........... Laughing
» Custom Domain Problem
» Custom domain problem..
» SCM Music Player Problem
» Custom Rank Title
