Take off the transverse sump guard. 12mm socket - You will need an socket extension to get to the chassis bolts. This is all the access you need.
The Oil Filter is near/inboard the Offside front wheel - sometimes the filter is horizontal and sometimes vertical. A Filter Wrench is recommended.
On mine it is vertical and its messy to remove!!
